Old 10-09-2007, 12:05 AM   #1
tenochiturbide
tenochiturbide's Avatar
454 Help!!!
Okay so we got the 454 out of the 87 chevy C30! the guy said the engine had about 60K miles so what sholud I do before drop it in my 72?? should I just clean it, change the gasktes, and drop it in place... rebuilt it to stock specs??? or put some good stuff in it!?? make it a performance?? I know i'll change it to carburator, put headers, aluminium intake, and is not going to have a catt!!! Aight, let me know what you guys think!!! sorry for the cell pictures, i didn't have the camera with me!! I'll do that next time~!~
Thanks!!!!
tenochiturbide is offline   Reply With Quote
Old 10-09-2007, 12:11 AM   #2
SactoJim
SactoJim's Avatar
Re: 454 Help!!!
Pretty open ended question........what kinda budget ya got to work with? I'd say do everything you can afford before putting it back in.
Depending on cylinder wear ya might get away with a re-ring, bearings, performance cam, aluminum manifold, etc....
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-09-2007, 01:21 AM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: 454 Help!!!
I'm a minimalist...check the compression and leak down...if it is good put on a manifold and carb and run it for a while. Well...ok...if you are dying for that rough idle put in a cam.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-09-2007, 02:40 AM   #4
72cheyennesuper20
72cheyennesuper20's Avatar
Re: 454 Help!!!
I agree less is more I tried the other way it just hurt my pocket book.
72cheyennesuper20 is offline   Reply With Quote
Old 10-09-2007, 10:17 AM   #5
70GMCer
70GMCer's Avatar
Re: 454 Help!!!
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-09-2007, 03:16 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: 454 Help!!!
Weiand has an Action Plus intake that is designed for those peanut port heads. That is what i used when I swapped in a 1989 C30's 454. I changed the cam and lifters and springs and the heads got a valve job - runs real strong and has torque way low which is great for my heavy K20.
You ought to really enjoy that motor!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Thread Tools
Display Modes
