Old 10-09-2007, 10:45 AM   #1
Bucky71
Heater problem
On the weekend i noticed that there was heat coming out the defroster vents even though the heater control slide was all the way to the left (off).
It wasn't doing this 2 weeks ago. What should I be checking? Could it be a linkage issue? or worse
Bucky71 is offline   Reply With Quote
Old 10-09-2007, 11:05 AM   #2
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Re: Heater problem
Is this an AC or Non AC truck?
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 10-09-2007, 03:13 PM   #3
Bucky71
Re: Heater problem
No AC.
Old 10-09-2007, 05:38 PM   #4
Lobo'74
Lobo'74's Avatar
Re: Heater problem
I just replaced my heater control box with a new one from GMC Pauls, and put in new cables. My setup had heat comming out when the temp was all the way to the left too. In my case it required properly setting the cable length from the end of cable attach point (by rotating it like a screw along the metal cable sheath) until I had a length that fully closed the heater when the lever was full left.
HOWEVER, if yours used to work fine but now puts out heat . . . I'm clueless.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Thread Tools
Display Modes
