Old 10-12-2007, 01:44 PM   #1
1969K10
1969K10's Avatar
X-fer Blues (t-221)
So, pulling out of the parking lot at work Wednesday, and I hear a clunk, and my truck has a serious no-go condition.
Fortunately, I got my daughter on her plane to go back home before this all happend.
So, locked the front axle in - no help. Can put truck in gear w nothing happening.
Anyway, last night finished getting the X-fer out, took the inspection cover off, and everything looked OK. So I looked back at the tranny, and found the coupler sleeve with no teeth on the X-fer end... Looked back at the X-fer, and I wouldn't call them teeth on the input shaft, I'd call them stubs now...
what a pisser! So now starts the search for a new X-fer or X-fer/tranny set-up.
Might as well go NP205 now. Does anyone know if my existing drive shafts will work?
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 10-12-2007, 04:36 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: X-fer Blues (t-221)
Sorry for your bad luck. Sorry don't know about the driveshafts. I believe the outputs are in slightly different areas height-wise so you could have a problem. Hopefully someone here knows for sure.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-12-2007, 04:56 PM   #3
1969k10stepside
I might have the 465/205 you need.You'll need a longer front driveshaft and maybe a shorter rear driveshaft.The crossmember and torque bracket will also have to be moved back some.The crossmember is also different but I dont know if you can make the existing one work.I might also have one of those crossmembers from a NP205 equipped truck.
Dustin
1969k10stepside is offline   Reply With Quote
Old 10-13-2007, 10:28 PM   #4
JAKES 68GMC
Aluminum slot wheels rule...
your gonna need a longer front shaft and shorter rear shaftm figure on moving the t-case crossmember back 2 inches. I used the Rockwell x-member with the 205, works fine, no problems.
JAKES 68GMC is offline   Reply With Quote
Old 10-13-2007, 11:13 PM   #5
brianthelion02
Overdrive club
brianthelion02's Avatar
I hated my rockwell,thing sounded like a jet airplane!!!!!!!LMAO!!!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 10-14-2007, 12:24 AM   #6
1969k10stepside
LOL.Mine never sounded like that,but it was just straight pipes so that concealed all other noises.. Mine never leaked bad either.It had a slow leak,but was never low on fluid.I guess the previous owner took good care of it.Heck,it only has 94,000 miles on it...
As soon as I finish building a 355 for the truck,it and this heavy tranny/t-case combo is going back in.
Old 10-14-2007, 01:25 AM   #7
earl87gta
earl87gta's Avatar
taht sucks Mine did the same thing now Im replacing it with a nv4500 and a 205. I thought I had tore the trans up and it had just been rebuilt. i dont think you will miss the jet plain sound.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-15-2007, 07:19 AM   #8
1969K10
1969K10's Avatar
Dustin
I think I found a replacement T-221 locally. IF not, dustin, I'll be getting a hold of you soon. I wouldn't mind losing the jet airliner sound, but don't really have anything agains the T-221.
Old 10-15-2007, 05:43 PM   #9
JAKES 68GMC
I've got 2 T-221's stashed away, one looks like new internally.
Old 10-16-2007, 10:59 AM   #10
1969K10
1969K10's Avatar
would love to take one of them off your hands, but shipping would kill me.
Dustin - PM sent
Old 10-16-2007, 04:48 PM   #11
JAKES 68GMC
Who said I was selling them???
Old 10-16-2007, 05:34 PM   #12
67mater
67mater's Avatar
I just rebuilt my T221 if you have any questions, and it's fun to hear everyone's feelings about the "airplane" hum; I agree 1969k10stepside; my straight piped cherry bombs seem to numb most everything.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 10-16-2007, 08:00 PM   #13
1969k10stepside
PM returned..you should be running around with a 465/205 in a few weeks...no wheeling till then though
Old 10-17-2007, 06:41 AM   #14
1969K10
1969K10's Avatar
Keep me updated Dustin. THX
Thread Tools
Display Modes
