Old 10-17-2007, 08:42 AM   #1
jaros44sr
jaros44sr's Avatar
Seals and Gaskets
I've got ATF in my NP205!!! And my search doesn't seem to be workin', could some one pls. give me a lead on a company to buy a seal kit. I've read about them before but my memory does not want to serve me...
Thanks J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-17-2007, 09:24 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Seals and Gaskets
4xheaven in Gloversville NY has all the 205 stuff. And its at my door in 1 day at ground rates.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-17-2007, 02:04 PM   #3
earl87gta
earl87gta's Avatar
you can get the seal kits on ebay for 25 . Most poeple get there rebuild kits from a guy on ebay cant remeber his user name but he sells complete rebuild kits for 130. thats the cheapest we have seen.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-17-2007, 05:09 PM   #4
jaros44sr
jaros44sr's Avatar
Was I wheelin with you at Rausch a while back, VT was there, and that guy rolled his pickup several times? You sound familiar, old age on my part
Thanks for the info guys I'll check them both out... J.
Yep, you were right. Vince can take care of it, mite as well put new U-Joints in it as well. Thanks for your time and help guys
SAFETY FIRST
AS usual, off topic
Jim
Old 10-18-2007, 07:41 AM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
I've never been to Rausch Creek. But i would like to go some day. In 2 weekends we are going on a trail ride up in the old strip mine near Shamokin.
Vince is a good guy, and he knows his stuff. You wouln't be dissapointed.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 10-18-2007, 05:04 PM   #6
jaros44sr
jaros44sr's Avatar
Musta bin another guy from Chester County, oh well. Thanks for the lead anyway
SAFETY FIRST
AS usual, off topic
Jim
Old 10-19-2007, 07:21 AM   #7
vtblazer
vtblazer's Avatar
I'd be interested in finding out more about this strip mine thing, sounds cool.
When are you going?
vtblazer is offline   Reply With Quote
Old 10-19-2007, 12:53 PM   #8
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Fel-Pro #TS80324 is the 205 gasket set, but I dont think it includes the output shaft seals.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 10-19-2007, 02:15 PM   #9
bdozeraz
bdozeraz's Avatar
Thanks J.
Its been awhile since I had the same problem but I got the seals from Napa. There are two seals in the adapter that you need plus an O'-ring. I replaced the seals and it continued to leak, then I found out about the O'-ring and that fixed it. I don't think a seal kit for the 205 will help you because I don't think they come with the seals for the adapter which is where your leak is coming from.
bdozeraz is offline   Reply With Quote
Old 10-19-2007, 03:44 PM   #10
jaros44sr
jaros44sr's Avatar
When are you going?
Hyjack my thread to find another wheeling trip, that's lowShoulda' said when is J and VT going
Dude you could syay at my place this time. shomkin's rite up the road
You think you had a bad day yesterday, I just got layed off
SAFETY FIRST
AS usual, off topic
Jim
Old 10-19-2007, 03:55 PM   #11
jaros44sr
jaros44sr's Avatar
It's aboot time I learn what's in my 205, I have an extra one for practice
I have like 25 gazillon megabytes of info some guy sent on a NP205 so it's time I read them!!!
Vince treated me real well, kinda like to help a Mom and Pop organization. He told me he would make sure to include the 'O' ring
I'ts good to know about the NAPA thing, I can carry spares
He said to make sure you put the coupling in the rite way there is a recess for it to sit in
SAFETY FIRST
AS usual, off topic
Jim
Old 10-19-2007, 05:14 PM   #12
vtblazer
vtblazer's Avatar
So let's set it up already.
Hi-Jack off, my work is done here.
Old 10-19-2007, 05:49 PM   #13
jaros44sr
jaros44sr's Avatar
Next weekend I'll be upstate NY for salmon, after that I'm open till I find a job....
SAFETY FIRST
AS usual, off topic
Jim
Old 10-20-2007, 10:40 AM   #14
orange72blazer
orange72blazer's Avatar
I have had this same problem for a few years. Where exactly does this o-ring go, because I dont remember seeing one or puting one in.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 10-20-2007, 10:54 AM   #15
jaros44sr
jaros44sr's Avatar
Inside the mount of your transfer case, there is a coupling shaft, joins the trans shaft and the tranfer case shaft. On the coupling shaft is a recess that should hold the 'O' ring. I'll post up a pic. when my seal kit and o-rings come in, and I tear it apart.. J.
SAFETY FIRST
AS usual, off topic
Jim
Old 10-20-2007, 11:54 AM   #16
orange72blazer
OK, thanks for the explanation, I have been asking this question for years but nobody could ever give me an answer. Could you give me the dimensions of the o-ring when your kit comes in. This would help me out a lot.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
Old 10-20-2007, 01:09 PM   #17
jaros44sr
jaros44sr's Avatar
Sure! No problem, if I forget post up again in a couple of days..... J.
SAFETY FIRST
AS usual, off topic
Jim
Old 10-21-2007, 06:29 PM   #18
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I had the same problem years ago with my 205 when my truck was still an automatic. The T case was so full of ATF it was blowing out the vent and covering the tailgate. At the time I bought a complete rebuild kit from National Drivetrain and just had to dig the box out again last weekend to pick more seals and gaskets out of it as it was leaking from just about everywhere. I also found the original invoice inside the box…. The kit was $130 in 1998 dollars. It came with enough bearings, seals, and gaskets to rebuild almost every 205 combination that was ever built. It looks like that kit is now $152.80 on their website.
While I have it this far apart I plan on yanking the 465 out and sealing it up as well. At least, I didn’t have an ATF leak this time as Zoomad75 and I converted the truck to a SM465 about 8 years ago under a cold and windy car port when we both still lived in Detroit. Actually, this is a different 205 than the one I had when it was an automatic. I used a complete donor truck for the swap that had to be turned into running condition again to sell.
Also gave it a fresh coating of IH red after resealing it. For some reason I like 205’s wearing red paint. 205’s were a redish color originally anyway.
DirtyLarry is offline   Reply With Quote
Old 10-21-2007, 07:49 PM   #19
jaros44sr
jaros44sr's Avatar
Nice work, and thanks for the info. I'm not doing bearings at this time, I just want to get the Jimmy on the road. Future mods are going to my spare 205
Are you sure all 205's were red, The numbers on the one in the truck says it was built in '71, but it's like a pontiac blue. Maybe the PO painted it
SAFETY FIRST
AS usual, off topic
Jim
Old 10-21-2007, 08:05 PM   #20
DirtyLarry
DirtyLarry's Avatar
I am pretty sure they were originally a deep red…..almost a plumb color. My dad bought our ‘78 tow truck brand new and I had a cherry all original ’72 Blazer that both had red transfercases and every one I seen laying around bone yards have some trace of red paint on them. I never saw a blue one before. PO must have done that.
I agree on the bearings….I didn’t do but one bearing in mine and I only did that one because it was easy to get to.
Old 10-22-2007, 06:36 AM   #21
How about this coupler shaft.Can this wear out and allow slippage and catching.Is it a spline that could get stripped?I have this problem in a truck where it seems to slip for a second when letting off(sometimes) and I get a nasty "clank" and a "grab" sometimes.There is some sort of slippage and it`s all gear:4spd/NP205 in a`72/stock.
Old 10-22-2007, 07:44 AM   #22
jaros44sr
jaros44sr's Avatar
In my experiences, mostly mechanical factory, sounds more like a bearing. A bad bearing will grab, if it gets hot that is another way to tell. You could have a little bit of debris on your balls... Just my .02
SAFETY FIRST
AS usual, off topic
Jim
Old 10-26-2007, 07:17 AM   #23
jaros44sr
jaros44sr's Avatar
Just got the seal and gasket kit in yesterday, thanks for the help guys... J.
I'll check out the condition of the bearings when I get to the disassembly
SAFETY FIRST
AS usual, off topic
Jim
Old 10-28-2007, 07:53 AM   #24
orange72blazer
Don't forget to give me the dimensions of the o-ring
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
Old 10-29-2007, 02:39 AM   #25
jaros44sr
jaros44sr's Avatar
Just got back in town, after fishing in NY. I'll try to post it up tomorrow... J.
SAFETY FIRST
AS usual, off topic
Jim
Thread Tools
Display Modes
