Old 10-25-2007, 01:16 PM   #1
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Axle swap
Can anyone tell me what modifications, if any, are needed to install axles from a '79 truck onto a '72 Jimmy.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 10-25-2007, 02:41 PM   #2
Burt4x4
Burt4x4's Avatar
Re: Axle swap
The front will bolt right in, your brake line fittings should work but may need to change the bajo bolt.
The rear your going to need to cut off the spring perches and move them inward adout 1 1/2" and probly the shock mounts will need changing...depends.
Other than that..can't think of anything else other than brake harware??
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-25-2007, 02:47 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Axle swap
Is the 79 a 1/2 ton or 3/4 ton? If 3/4 ton, you will need a conversion u-joint for the rear driveshaft to axle location.
When I did a 3/4 ton swap to my 70 K5 I found my stock hard lines wouldn't bolt up to the rubber lines. I went ahead and just made up new hard lines with the right fittings.
Burt's dead on about the rear axle spring perches, unless your 79 happens to be a 1 ton, then the spring perches are in the right position.
It's a pretty straight forward swap.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-25-2007, 02:48 PM   #4
Chevyman63
Chevyman63's Avatar
Re: Axle swap
Thanks for the help Burt. Now to pass on the info and see if it is worth it or not.
Thanks to you as well Mark. I knew I could count on everyone here.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Thread Tools
Display Modes
