Old 10-27-2007, 07:55 PM   #1
BCOWANWHEELS
C-notch Need Pics
I,am fixing to do a C-NOTCH on my frame. i,am going to build my own notches. does anybody have some close up shots of home builts, bolt ins or store boughts i could see some pic,s of. also with them installed ? lastly where to install them at exactly.
thanks
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-27-2007, 08:14 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: C-notch Need Pics
My 77 Cheyenne....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-27-2007, 08:16 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
n2billets 84-
Articles-
"Refining Sierra"
Old 10-27-2007, 09:14 PM   #4
BCOWANWHEELS
that looks good. you built em right ?
Old 10-28-2007, 11:00 PM   #5
steveo10
steveo10's Avatar
heres a pic of mine when i was building it. they are kp 63-72 notches.
steveo10 is offline   Reply With Quote
Old 10-29-2007, 01:30 AM   #6
earl87gta
earl87gta's Avatar
Bob ,
When I did my 94 I set it right down on the axle to see were it was going to hit. then I cut a peice of 6 in pipe in half and welded it to the frame over the axle then I cut the notch out and finnished boxing it in. wish I had pics but back then I couldnt aford a digital cammra. I did the work at the hobie shop on base.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-29-2007, 01:53 PM   #7
MisterE72
Keep Your Nose Clean
This may not a little. Mine was a $100 kit from classic performance. Its a bolt on but I had it welded on as well. Hope they help. Best of luck on your build.
MisterE72 is offline   Reply With Quote
Old 10-29-2007, 02:26 PM   #8
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
That's what I did on my truck as well... I bolted the notch in, welded it, removed the bolts and welded the holes in. After the frame was powdercoated you could hardly tell anything was modified.
IMHO, $100 is cheap depending on whether you will be doing the fabrication yourself and how you value your time. You could spend $100 pretty quick if you have to pay someone to build the notch for you. I did all the cutting and installing for mine then hauled the frame over to a buddy's shop to get about an hour's worth of welding done.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 10-29-2007, 10:30 PM   #9
BCOWANWHEELS
mister e72,
you burn a rod real good pal. not too many good stick welders anymore.
regards & thanks
bob
Thread Tools
Display Modes
