Old 10-31-2007, 07:32 PM   #1
BCOWANWHEELS
Small Block New Thumper Camshaft
I HAVE A BRAND NEW ENGLE HYDRAULIC HOT ROD CAMSHAFT. this has never been in a engine. its a maxed out hydraulic grind like for pro street performance etc. power band is from 2500-7000 rpm,s . its recomended for 10-1 compression and up. if you want a cam that racks off this is it. i paid almost 300.00 for this and i,ll sell it for 125.00 delivered.
bob
spec,s.
in. 520 - exh. 537 lift
in. 294 - exh.310 diration
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-31-2007, 10:43 PM   #2
BCOWANWHEELS
Re: Small Block New Thumper Camshaft
ttt
Old 11-01-2007, 08:17 AM   #3
396muncie
396muncie's Avatar
So this is an Engle cam, not a Comp Cams Thumpr cam, right? I couldn't find it on the Engle Cams website. What's the duration at .050 and the Lobe Seperation Angle(LSA)? Is it flat tappet or roller? Any part #? Thanks
70 Custom/10, 396, Muncie 4spd, SWB SOLD
72 Cheyenne K20, 350, Granny 4spd, LWB, daily driver
72 Cheyenne Super C20, 350, Turbo 400, LWB, parts truck for 4WD Cheyenne
396muncie is offline   Reply With Quote
Old 11-01-2007, 12:49 PM   #4
BCOWANWHEELS
grind number EP28/30-HYD, INTAKE OPEN @20 EX CLOSES @22, INT. CLOSES @48 EXH. OPENS @ 58, GROSS CAM LIFT INT. 347 & DUR.@.050 IS 248,
GROSS CAM LIFT EXH IS 358 WITH DURATION 260 @.050.
LOBE CENTERS 106
ITS A HYDRAULIC LIFTER CAM , BIG AS YOU CAN GET AND WHAT THE ANTI PUMPUP LIFTER IS CAPABLE OF.
ITS NOT IN THE ENGLE BOOKS ITS A SPECIAL HI-PERF SBC CAM FOR PRO-STREET USE.
Old 11-01-2007, 06:01 PM   #5
396muncie
396muncie's Avatar
Do you have the cam card with this? Any lifters to go with it? Are you flexible on the price at all? Thanks
Old 11-01-2007, 07:47 PM   #6
BCOWANWHEELS
MAN I,AM TAKING a big hit as it is. 125.00 delivered is about giving it away. it was over 300.00 after shipping. no theres no lifters just a brand new cam.... and yes the cam card is with it from engle.
bob
Old 11-02-2007, 01:21 PM   #7
BCOWANWHEELS
Ttt
Old 11-02-2007, 07:02 PM   #8
396muncie
396muncie's Avatar
Well, if you get to the point where you'll take $100 shipped, let me know. Not trying to offend and if you can't go that low, no problem. Thanks
Old 11-02-2007, 07:03 PM   #9
BCOWANWHEELS
i wont go that low and you wouldnt also. but thanks
Old 11-28-2007, 04:47 PM   #10
BCOWANWHEELS
ttt
Thread Tools
Display Modes
