11-02-2007, 09:38 PM | #1 |
What gears do I probably have?
I have a '72 Blazer and it was mostly stock when I got it. Was 3.07 the common 4x4 gearing used stock? I just lifted 6" and put on 35's and it goes really slow up any type of grade now. I am guessing gearing is the issue. I don't have $1,500 to re-gear right now so will have to live with it.
11-02-2007, 09:43 PM | #2 |
Re: What gears do I probably have?
The motor,and tranny play a role in the gears it had..I believe with a 350 and a auto it had 3.07s unless other wise ordered.I don't know for sure but with a 4spd I think it had 3.73s standard..I'm not for sure though.Pull the cover,get the numbers off the ring gear and find out...Is that what it will cost to swap gears out front and rear,$1500? I'm glad I can do this stuff myself..it only cost me the ring & pinion,and new bearings,and a few gaskets--I had $200 total in swapping to 3.73s..Then I spent a little more on parts to redo the axles completly since they were already apart..
11-02-2007, 10:00 PM | #3 |
Future TOTM Winner
I believe you got them swapped. A 4x4 with a 350 engine and a 350 auto should have 3.73 gears(mine is that way), but a 350 v8 with a floor shift manual would probably be 3.07s. As far as 2wd or a three speed on the column, or a 6 cylinder...someone else will have to give you that info
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
11-02-2007, 11:41 PM | #4 |
I'm a poor spectator
Mine is a factory 4 speed with factory 3.07's.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
11-03-2007, 12:34 AM | #5 |
SKINNY TIRES RULE!
Mines a factory 350/TH350 with 3.07's. My understanding was that the 3.07s were standard, but a huge portion were shipped/sold with 3.73's.
35's are a bit tall for 3.73's. 4.10's are much better suited for 35's. Save your money and swap up to 4.10's. You'll get better gas mileage and better pickup off the line.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
11-03-2007, 10:03 AM | #6 |
Post Whore
My GM restoration pack for 1970 K5's shows for the 4wd K5, 3.73's were standard with all engines except for the 350 V8 which it shows only got 3.07's.
For whatever reason it doesn't show any optional gear ratios for the 4wd K5's. For the 2wd 1970 K5 it shows: 3.73 was standard for the 250 six regardless of transmission and standard with the 307 V8 with a three speed. 3.07's were standard for the 307 V8 and 4 speed manual or auto, along with any 350 V8 combo. 4.11's were optional for all and if it had the 3.73's then 3.07 was an option and if it had 3.07's then 3.73's were also optional.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
11-03-2007, 10:30 AM | #7 | |
Future TOTM Winner
11-03-2007, 12:05 PM | #8 |
Post Whore
I wouldn't take that restoration packet as gospel, but that is what it states.
11-03-2007, 12:51 PM | #9 |
SKINNY TIRES RULE!
My first 72 CST had 3.73's with a 350/TH350. I don't think consistency was one the most common practice back then.
11-03-2007, 02:08 PM | #10 |
The packet is incorrect.. My '70 is equipped with 3.73 gears.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-03-2007, 02:10 PM | #11 |
Blazerless
My '72 had 350/th350 and 3.07's stock.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD 69' Beaumont 388/700R4 11.70@116 77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad. |
Thread Tools | |
Display Modes | |
