Old 11-03-2007, 08:43 PM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
those with 8"+ lift..........
What have you done for driveline angles? I am getting a slight vibration slowing down and taking off, I have 8" suspension lift with 35's. 465/205 and dana60 rear. What have you done?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 11-03-2007, 09:09 PM   #2
earl87gta
earl87gta's Avatar
Re: those with 8"+ lift..........
Is it only in 4wd or does it do it in 2wd too. It sounds like its time to upgrade to some new highangle drive shafts. you could also move the front axle forward some and the rear axle back.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-03-2007, 09:50 PM   #3
bigbadchev72
People know me
no front driveline yet.......Its sitting in the garage, but I figure if I dont have one in I wont be tempted. I do have a zerorate in the back and moved the rear axle back already. I have been looking for a bronco driveline to use, but just wondering what everyone else has done. I know the bronco one is only 1/2 ton, But I dont care it just sees the street and I never get on it, so it is pretty much babied all the time
Old 11-03-2007, 10:38 PM   #4
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Here is my Jimmy! 8 1/2 inch lift 35 inch super swamper's tsl's
Angelse68cal is offline   Reply With Quote
Old 11-03-2007, 11:05 PM   #5
bigbadchev72
People know me
Have you driven it? Get a vibration? what do you have for a driveline?
Old 11-03-2007, 11:14 PM   #6
bdas70chevy
bdas70chevy's Avatar
myn did that with a 4 " before the Zero rate in the back springs. i think it is the drive line angle.
bdas70chevy is offline   Reply With Quote
Old 11-04-2007, 08:48 AM   #7
vtblazer
vtblazer's Avatar
CV joint with pinion rotation.
vtblazer is offline   Reply With Quote
Old 11-04-2007, 10:02 AM   #8
pumpkin
pumpkin's Avatar
Is that a rotor for a park brake? If it is, how'd you make it?
pumpkin is offline   Reply With Quote
Old 11-04-2007, 12:04 PM   #9
vtblazer
vtblazer's Avatar
Yes it is but it was purchased.
It's from Jesse @ High Angle Drive line.
Old 11-04-2007, 01:52 PM   #10
jaros44sr
jaros44sr's Avatar
Cool, nice mod. How'd I miss that? Is it mounted behind the pinion nut? You keep changing that and it's not going to look like a first gen.
I don't see any cables going to it, how does it work?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Thread Tools
Display Modes
