11-06-2007, 02:48 PM | #1 |
Having issues
Rent = due + no job = sell everything!!
I am working again for now, I do not have the time to deal with shipping any of this stuff, so for now its only local pickup. When things change, I will bring this thread back up.
I have my parts accumulation that I need to dump. I hate to do it, took me a long time to get some of this stuff, blah blah blah, etc etc, the old lady says I have to get rid of it all, or get a job. Jobs are scarce, the housing market is on a downward spiral, so imma fixin to dump it all. If you don't like the price, shoot me a reasonable offer. The more you buy, the better the chance of me coming down on the overall price. The larger items I am not going to bother with shipping, you get nic's a $75 upcharge. For starters, '71 K20 Stickshift transmission crossmember, $75 K20 HD44 front end, 4.10 gears, needs rotors, $400 with lockouts. No shipping Locking hubs with decent to good chrome, mismatched dials, $200 Power brake booster with firewall brackets, untested, as-is $50 Steering shaft, tight $50 Clutch frame bracket, Zbar, and rod to clutch pedal $60 Clutch pedal assembly $50 Steering gear, untested, as-is core, $40 H052 rear end, 4.10 gears $250 I have 2 H072 rears, one with 1/2" studs, one with 9/16" for $300 ea, 4.10 open. 1 piece driveshaft, 1350 joints, $125. '71 GMC Jimmy Seat cores. 1 broken spring on the passenger side $75 pr. All hardware incl. No shipping SM465/NP205 combo $300. Tcase needs a bearing replaced on the back of the input shaft, tcase is free (with the transmission) :P 10 bolt front end, 4.10 gears, what you see is what you get. $75 No shipping All glass is No shipping/ship at your own risk Two windshields, both in excellent shape, $100 each. One windshield that has a chip, and some scratches from improper wiper maintenance, $40. One pair (L+R) door glass and vents. One drivers side fender in excellent shape (69-72) $75 Two non slider rear windows $50 ea. Non AC fan, $20 motor+ fan Wiper motor $30 Good core support, rusty battery tray $65 Eaton rear end shafts $75 PR long and short side 4.10 third member $75 12bolt rear 3.08 posi, from '72 blazer needs brake hardware kit, $75 stock air cleaner $10 Carb to air cleaner spacer, $20 Blazer hatch struts, rear hold downs, and latch clips, $80 all. Cable style throttle assemblies $40 w/o cable More to come Last edited by masterbeavis; 11-11-2007 at 01:05 AM. |
11-06-2007, 02:56 PM | #2 |
Re: Rent = due + no job = sell everything!!
I'd be interested in the bucket seat brackets if you will ship.
11-06-2007, 02:58 PM | #3 |
Having issues
2 aux fuel tanks. I have yet to pull them and verify they arent full of rust, $50 each. I have a drivers side that is confirmed good from a different truck
HD44 hubs, ok chrome, dials broken. PM me a reasonable offer. I have all kinds of do-dads I need to fish thru the garage to find, and take pictures of. Last edited by masterbeavis; 11-11-2007 at 01:05 AM. |
11-06-2007, 04:31 PM | #4 |
I am interested in the aux fuel tanks for my truck. Are you going to pull them and check for rust? Are you willing to ship? My zip is 84037. Thanks.
11-06-2007, 04:36 PM | #5 |
Having issues
Gas tanks are iffy in the shipping department. If these tanks let off so much as a whiff of gasoline fumes, they will stop it mid shipment and return them. It has been my experience with these tanks that the bolting hardware does not survive the removal process, so all you would be getting are the tanks without any bolts. (or at least bolts with the heads cut off.
To answer your question, yes I will pull them, yes, I will check for rust, yes I will ship, on your dime. [edit] Uncle, if the seats do not sell in their entirety(sp) I will separate them. Last edited by masterbeavis; 11-06-2007 at 05:13 PM. |
11-06-2007, 05:20 PM | #6 |
Having issues
More stuff. I will add prices and descriptions later on tonight.
Chrome wing vents, complete with overspray. THey look to be in OK condition. $40 pr. Power drum brake booster, from a 70 C20, tested, and working $80 Door window regulators, and door latch and handle assemblies, $40 all Two pairs of 3/4 ton two piece driveshafts, 1350 Ujoints, with good carrier bearings $75 each pair High hump trans cover $40 Good drivers side fender, no rust $50 Good windshields, $100 each (local delivery/pickup only) Front bumper clips, and front spring hangars, $40 for each side, frame included. If you want only the hangars, add another $20 for me to separate. Last edited by masterbeavis; 11-07-2007 at 11:38 PM. |
11-06-2007, 05:21 PM | #7 |
Having issues
Frame chunks are $10 a foot, rounded up at 6", except front spring hangars, priced separatly. Cross members count per foot, I will separate the frame if you desire, but you wont save any money.
Eaton 5.14 third member. Shipping is expensive on this one, over $150. Radio, as is, unknown condition, $30 Blazer fuel fill hose cover, $40 K20 power steering box, in OK shape, $75 Last edited by masterbeavis; 11-07-2007 at 11:46 PM. |
11-06-2007, 05:22 PM | #8 |
Having issues
Box o crap. If you see something you want, PM me about it.
Older GM horn, with a bracket booger welded on. Tested, $15 71 C20 power disc booster, with linkages $65 green arm rests, $10 bench seat brackets $10 misc pulleys and brackets, PM offer. Misc 1/2 and 3/4 ton parts. Rotors, hubs, spicer locking hubs, front axle U bolts, misc chingaderas.. PM offers. Tailgate. Top fin is pretty straight, no rust I can see or know of, one dent on bottom, $75 Last edited by masterbeavis; 11-07-2007 at 11:53 PM. |
11-06-2007, 05:27 PM | #9 |
Having issues
11-06-2007, 06:18 PM | #10 |
Have any front driveshafts?
11-06-2007, 06:20 PM | #11 |
Having issues
Not ones that have super tight CV's. They are good enough to get you by a couple of years however.
11-06-2007, 06:22 PM | #12 |
I'm waiting to see if another member has one,if not I might be interested in one.
I also need drivers side seat tracks for a set of bucket seats.Could you check on shipping on the bucket seats for me to 47578.I might be willing to pay that price for just the tracks,but might as well have the seats too,And front bumper brackets for a 67-70 4wd,maybe a set of 71-72 4wds also. Last edited by 1969k10stepside; 11-06-2007 at 06:23 PM. |
11-06-2007, 06:44 PM | #13 |
Having issues
Bumper brackets? I thought they bolted to the frame, and had a little L clip looking thingie? I only have 2 sets of those, both from '71 K20's. The larger brackets I have are bent.
The buckets are too large for me to ship. I have previously made a deal with another member for the brackets if the seats do not sell locally. Last edited by masterbeavis; 11-06-2007 at 07:00 PM. |
11-06-2007, 06:45 PM | #14 |
those rear driveshafts is either one 52-53" from eye to eye, and will you ship to ny
11-06-2007, 06:55 PM | #15 |
Having issues
I will have to check on the legnths. The two that are pictured that are double are from the same truck, a LWB 2WD, that had a stickshift in it. I will ship that on your dime, I dont think there is a size surcharge on that size of a package.
11-06-2007, 08:15 PM | #16 |
Luv the Crewcabs
Chrome Vent 's Shipped to 46702???
Thanks, Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
11-06-2007, 08:38 PM | #17 |
looking for emergency brake parts inside the drums of an eaton 3/4 ton rear.
wtb add- http://67-72chevytrucks.com/vboard/s...68#post2433868
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
11-06-2007, 08:44 PM | #18 |
Trying to convert to auto xmsn - do you have any linkages or crossmembers?
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
11-06-2007, 08:45 PM | #19 |
How much for the 205 knob post #8 first picture? thanks Mike
11-06-2007, 09:46 PM | #20 |
looking for a set of front bumper brackets for a 71 4X4. I live near chico and I could pick them up. let me know. thanks Rick
11-06-2007, 10:34 PM | #21 |
Having issues
Ace, I do not have any parts laying around, only complete axles.
9teen: I do not have any automatic 4WD parts. Down south: Let me dig the knob out and make sure it is a good one. Ricks, I only have what is pictured, the outer brackets are damaged, or MIA.0 |
11-07-2007, 06:21 AM | #22 |
Straight jacket required
Do you have a tilt floor shift column for sale? If so, how much to 79602? Thanks.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." |
11-07-2007, 08:13 AM | #23 |
plz put me in line for the VENT WINDOWS..
thanks
11-07-2007, 09:41 AM | #24 |
masterbeavis, would you happen to have an engine crossmember for a 4x4? if so, how much shipped to 77040, business?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
11-07-2007, 10:11 AM | #25 |
Having issues
I only have a non tilt floor shift column, and I do not have anymore 4x4 engine cross members.
Thread Tools | |
Display Modes | |
