11-09-2007, 08:56 PM | #1 |
3/5 drop questions
looking at getting a 77 swb, i want to do a 3/5 drop, what is the easiest/least expensive way to do it? who makes a good kit? what have you used and was it fairly quick & easy? pics would be great also, thanks. i appreicate the feedback & replies.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat) |
11-10-2007, 12:09 AM | #2 |
Dark Heart Motorsports
Re: 3/5 drop questions
prolly the easiest way I've found for that kind of drop to date... Is a flip kit in the rear, and 2.5" coil drop in the front.
no pics, wayyyyyyyyyyyyyyyyyyyyyyyy to many to filter through.
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
11-10-2007, 05:35 AM | #3 |
It Is What It Is,,,,
But the great thing is that you have many options on what way you want to drop it.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
11-10-2007, 10:54 AM | #4 | |
Insert Witty Text Here
A flip kit should be fine for the back. The amount of drop is dependent on the thickness of your springs. More leaves = more drop. It might not end up exactly where you want it. Folks who have done a flip kit should be able to give you a good ide of how much drop you'll get if you tell them how many leaves you have. I bought my parts at performancesuspension.com. No complaints. You might also look at the parts Summit Racing sells. They seem very reasonable. Western Chassis and DJM parts get good reviews here on the site. Slonaker |
11-10-2007, 11:37 AM | #5 | |
350+dual flows= fun :)
quick question: im getting all DJM, "i live about 5 blocks from them" i dont want to go with the dropped spindle, due to the fact i plan on using my rallys...and dont want any grinding or rubbing... so im going with the LCA, and the dropped coil... will those provided good suspension travel?
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!! SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!! |
11-10-2007, 01:16 PM | #6 |
www.73-87chevytrucks.com
LCA's are fine, I ran them on my truck for years.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Thread Tools | |
Display Modes | |
