Old 11-10-2007, 03:55 PM   #1
turner15
Shifter Arm Install Help???
So I am reinstalling the shifter arm on the column and can't seem to get it right.
I can't find the spring thing and it seems to stop going all the way into the socket. Any ideas as to how to do this? I've attached so pics.
I think I am just missing a step or 2.
turner15 is offline   Reply With Quote
Old 11-10-2007, 04:02 PM   #2
berencam
berencam's Avatar
Re: Shifter Arm Install Help???
its always just fit right in for me. are you sure you are getting the ball to go into the joint correctly. is that the original shifter arm your using?
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 11-10-2007, 04:11 PM   #3
turner15
yes the original everything. I only have 3 shifts on the shifter at this time? I was told there is a safety thing that prevents the other 2 positions on the shifter when the arm is out.
Old 11-10-2007, 04:36 PM   #4
68SHORTBOX
68SHORTBOX's Avatar
Check the small hole that the ball end of the shifter fits into there may be a small anti-rattle bushing in the hole, if it is not lined up correctly lever will not go all the way in.
68SHORTBOX is offline   Reply With Quote
Old 11-11-2007, 08:58 AM   #5
turner15
So I got some bad advice thinking there was a spring in the column that made you move the shifter forward to shift, like in the more modern trucks.
So there isn't one. I have the linkage jammed in just above the lower bearing. Once I pried it into the right position it works again.
Thread Tools
Display Modes
