Old 11-11-2007, 09:37 AM   #1
1966gmc
Why does it taste purple?
1966gmc's Avatar
Another rearend question if I may
I am in need of converting the rear thats in my 66, dana 44 with leafs.What leaf spring rear with a 5 bolt pattern bolt in if any.I have not found any 5 bolt axles that will no work in my Dana 44.I dont wanna convert to rear coils.Too much fabbing to get it to work.Any suggestions?
1966gmc is offline   Reply With Quote
Old 11-11-2007, 10:06 AM   #2
60-66 Nut
Professional Beer Tester
Re: Another rearend question if I may
I have a 1966 GMC parts truck, which I was told has a rearend that someone had taken out of a 1979 Chevy or GMC 4WD truck. It is of course still 6 lug being from a 4WD, but I believe the spring perch widths are the same between 2WD and 4WD in 1973-1987 1/2 and 3/4 ton trucks. Just measure your spring width from center of one spring to the center of the other, and go check out some junkyard trucks. Also with the 73-87 trucks you have a better chance of getting something with some more highway-friendly gears.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Thread Tools
Display Modes
