11-14-2007, 04:58 PM | #1 |
trans to bell housing ???
ok i when to bolt my 4 speed up to me bellhousing and the hole in is too big by about 1/4 " (see first pic)
is this gap a problem or can i just bolt it up and not worry about it?? everything eles fits great
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
11-14-2007, 05:06 PM | #2 |
Re: trans to bell housing ???
also is this a ratio?
1st 3.50 2nd 2.48 3rd 1.65 4th 1.00
11-14-2007, 05:08 PM | #3 |
Not a problem IMO.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
11-14-2007, 05:09 PM | #4 |
Looks great to me.
11-14-2007, 05:21 PM | #5 |
i was told that i hekps the align the trans, but if it goes into the clutch fine and the bolts line up than it should be fine right?
11-14-2007, 06:35 PM | #6 |
Watch out for your cornhole !
Some guys who I really respect have told me that a thin spacer ring is order of the day there. It's critical that the crank and mainshaft centerlines are identical.
11-14-2007, 07:18 PM | #7 |
where can i get this spacer ring?
11-14-2007, 07:58 PM | #8 |
The main guy I remember is a HAMB'r named Squirrel. I believe he wound up making his own.
11-14-2007, 08:09 PM | #9 |
would you happen to know how he made it?
11-14-2007, 08:19 PM | #10 |
Knowing that maniac, I'm sure he made one out of billet steel on a lathe and mill. He's way beyond me when it comes to this stuff.
11-14-2007, 08:34 PM | #11 |
Fabricate till you "puke"
You can also use the input bearing retainer from a saginaw 3spd(68-up truck), or opt for a 67 or older truck bell to run the car trans....L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-14-2007, 09:45 PM | #12 | |
i do have 2 saginaw 3 speeds to take one off (if i new what one was)
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB Last edited by cstm68; 11-14-2007 at 09:46 PM. |
11-14-2007, 09:53 PM | #13 |
It's that big cast iron front piece that fits into the bellhousing bore.
11-14-2007, 11:33 PM | #14 |
so if i pull thoes 4 bolts out will it just slide off over the shaft?
will it take anything out with it or will anything try to fall out? by the way thanx for all the help guys
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB Last edited by cstm68; 11-14-2007 at 11:33 PM. |
11-15-2007, 12:43 AM | #15 |
Member #1049
Yes, Just remove the bolts and it will slide off.. nothing will fall out.
11-15-2007, 01:13 AM | #16 |
thanx for all the help.
11-15-2007, 08:47 AM | #17 |
just go get the right bell housing. I wouldn't run that tranny with all of that clearance in the bell. Bell housings are cheap.
11-15-2007, 09:31 AM | #18 |
There is a gasket to replace, & a seal inside the collar. You will be wise to go ahead & replace the front bearing on the input shaft while you are in there. i have seen that front bearing let go & scatter the trans. When you pull the collar, you will see a snap ring on the input shaft.....remove that & carfully wiggle the bearing off. The shaft should stay with the trans, but will try to move foward. I would hold pressure rearward on the shaft to keep the shaft in place,& 4th gear syncro in its keys. Button it up & you are good to go. The truck bell(68 -up) has a 5 1/8" center hole, vs the 4 11/16" hole for the car , or the 67 & older truck. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 11-15-2007 at 09:33 AM. |
Thread Tools | |
Display Modes | |
