Old 11-18-2007, 03:14 PM   #1
tk1251k
tk1251k's Avatar
Smile heater a/c blower switch
Ny fan switch I have replaced a couple times . I need to replace the plug that plugs into the switch it has four wires. Its in bad shape I had a fuse to blow and that I think is the problem. Anybody put a new plug and if so will wires have to be cut. thanks terry
tk1251k is offline   Reply With Quote
Old 11-18-2007, 04:06 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: heater a/c blower switch
I haven't replaced the plug, but I've gone through 2 switched, hi-speed relay, relay and resistor. I need to replace the high-speed wire harness. The plug at the fuse block is bad.
You can buy a complete harness that will have the plug in place, otherwise, you'll probably need to cut and splice wires.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Thread Tools
Display Modes
