11-20-2007, 03:31 PM | #1 |
67-72 Addicted
Cab
Are all 67-72 cabs the same? or are there some differences?
11-20-2007, 03:59 PM | #2 |
Re: Cab
Some '67 cabs had the small rear window. The 1972 cabs had an air vent in the drivers side door opening. Then the other differences were low/high hump, and A/C non A/C. The 40-60 series cabs are similiar, but all of those had the small rear window, and there are other minor differences.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-20-2007, 08:40 PM | #3 |
Re: Cab
67-68 emergency brake is hand operated, under steering column
69-72 foot operated, mounted on firewall by drivers side kick panel 67 small ignition lock switch hole doors, different window regulators because of trim panels plus 72 has an extra screw for the vent window frame if I remember correctly Basically they will interchange some trim differences |
Thread Tools | |
Display Modes | |
