Old 11-23-2007, 01:37 AM   #1
Farmstore34
Farmstore34's Avatar
Question Need ignition help
Hi all,
I am working on a 1989 Chevy Blazer that belongs to my sister. The previous owner ran the motor out of oil and grenaded it. We built a new 350 engine for it and just finished swapping it in. We got everything hooked back up and the new engine fired right up. We ran it at high idle to break in the cam for about 20 min and shut it off and restarted it a few times, no problem. Went out for a test drive and it suddenly quit. I checked around and found that we have no spark coming out of the coil. I double checked all connections, made sure theres juice going into the coil but can't find anything wrong. I suspect either the coil or the ignition module inside the distributor. Any other ideas? This is so frustrating! Thanks,
Colby.
Farmstore34 is offline   Reply With Quote
Old 11-23-2007, 01:52 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Need ignition help
Pull the module and take it in to one of your better local auto parts stores and see if they can test it for you. As for the coil, you can check the ohms resistance between the contacts at various points of contact, make note of the readings and then compare them to a new one. Any great variation I'd say replace the coil. but most likely culprit is the module in the distributor.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-23-2007, 10:07 PM   #3
Farmstore34
Thumbs up Re: Need ignition help
Bingo! The ignition module was bad. Blazer is now running great! Thanks BLE.
Colby.
Thread Tools
Display Modes
