Old 11-24-2007, 04:41 PM   #1
thump16
thump16's Avatar
carb issues
I have an 84 silverado and I picked up a working quadrajet from a 85 silverado that has an electrical plug on top. How do I get this carb to work on my truck without having the wiring for the dual capacity pump? If there is a simple solution please help.
thump16 is offline   Reply With Quote
Old 11-24-2007, 05:32 PM   #2
thump16
thump16's Avatar
Re: carb issues
somebody help
Old 11-28-2007, 10:21 PM   #3
86-C10-V6
Shadetree Mechanic
86-C10-V6's Avatar
Re: carb issues
The best suggestion I could make is to add the wiring. It's just 12 volts through a thermostatic switch. That lowers the fuel pump capacity once the water temperature rises above the set point.
You could probably salvage it off of a truck in a junk yard.
You could just wire it hot all the time, but then cold temp operation would not be as good.
Hope this helps.
Dave M. (Hacksaw)
86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance
89 GMC S-15 Extended Cab 4x4, 4.3L, FI
98 K1500 Xcab, 5.7L, 3.43 Gov-Lok
86-C10-V6 is offline   Reply With Quote
Thread Tools
Display Modes
