Old 11-27-2007, 02:03 PM   #1
OldCreek
OldCreek's Avatar
Measurement Needed: Rear cab mount - Front Bed mount
Can someone measure the center hole of the rear cab mount to the center of the hole on the front bed mount. (frame length between the two.) I need to mount the bed onto a bare frame.
(SWB ... But I dont think that matters)
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 11-27-2007, 04:05 PM   #2
DREAMS OF A 67
Step Brother
DREAMS OF A 67's Avatar
Re: Measurement Needed: Rear cab mount - Front Bed mount
I laid a straight edge across my frame, centered the rear cab mounts and measured 7 1/4" to the center of the first bed bolt. Is that the measurement you needed?
DREAMS OF A 67 is offline   Reply With Quote
Old 11-27-2007, 04:59 PM   #3
OldCreek
OldCreek's Avatar
Yup.
Also, do all the mounting points on the bed line up on the same horizontal plane? ( If so, I assume that plane is parallel to the ground.)
Old 11-28-2007, 07:19 PM   #4
DREAMS OF A 67
Step Brother
I think it would be parallel to the frame, most trucks slant toward the front. The bed should match your body lines.
Thread Tools
Display Modes
