Old 11-29-2007, 06:22 PM   #1
70clone
70clone's Avatar
Will a 67-72 body fit on a 73-87 4x4 frame
i was wanting to know if this is an easy conversion since the 67-72 swb 4x4 are hard to come by
70clone is offline   Reply With Quote
Old 11-29-2007, 06:26 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Will a 67-72 body fit on a 73-87 4x4 frame
Try to find this topic using the search tool. Also, try private messaging Mudder on this topic. He has done it. It can be done with a little work. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-29-2007, 06:42 PM   #3
krue
Designated A-hole!
krue's Avatar
Mudder is the one to talk to, it's definitely doable, but due to differences in the frame you'll need to do a body lift.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-30-2007, 11:40 AM   #4
70clone
70clone's Avatar
thanx guys i emailed mudder
Old 12-01-2007, 12:27 PM   #5
Mudder
Mudder's Avatar
did you get the info i sent?
Mudder is offline   Reply With Quote
Old 12-01-2007, 12:30 PM   #6
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Would it be Possible for me to Get the Same info on Doing a Conversion??
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 12-02-2007, 03:59 AM   #7
Mudder
Mudder's Avatar
pm me your email addy.
Old 12-10-2007, 02:33 PM   #8
72chevy327
wow i was interested in the same swap, do you mind sending it to me also? Thanks Quinn.
72chevy327 is offline   Reply With Quote
Old 12-10-2007, 03:22 PM   #9
Mudder
Mudder's Avatar
pm me your email addy if you dont want others to see it here.
Old 12-11-2007, 06:27 AM   #10
I looked at a truck with this swap and it looks like the biggest thing is up front.The`73-up core support mounts forward of the pre-73.This one was done less than correct in my book.The cab mounts were all used and the frame mounts were just off-center side to side,but still used.
Old 12-11-2007, 07:45 AM   #11
Mudder
Mudder's Avatar
It can all be done pretty easily. Would be awesome if the 67-72 cabs had a higher opening in the rear of the cab.
Old 12-11-2007, 10:36 PM   #12
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
id like to see this info as well if you dont mind milehightoyz@hotmail.com
milehightoyz is offline   Reply With Quote
Old 12-12-2007, 12:24 AM   #13
Mudder
Mudder's Avatar
sent
Old 12-12-2007, 11:24 AM   #14
72chevy327
got em thanks Mudder. so to me it looks like a body lift with some steering mods and something done to the core supports. can you please do a more in depth list of all the mods necessary to complete the swap, if you don't mind, i would appreciate it and probably other members too. Thanks again Mudder.
Old 12-12-2007, 11:40 AM   #15
toomanytoyz
Luv the Crewcabs
I have used the Shaft from a 90's Jeep Cherokee for a Similar Swap, Has 2 ujoint's in it & was a Direct Bolt in............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-12-2007, 12:22 PM   #16
Mudder
Mudder's Avatar
Did you get the little deal I wrote about what I did? The only other thing not there would maybe be shortening the rear brake lines a little and I'm not even sure anymore that I had to do that. I would have to look the next time she lets me see her.
You could call me if you have specific questions or ask here and hope I can answer.
Old 12-14-2007, 02:07 AM   #17
Why does the steering shaft need offset?The frames are the same width and the axles bolt up the same.The same steering box was used through`75,too.I`m just confused.
Old 12-14-2007, 02:31 AM   #18
toomanytoyz
Luv the Crewcabs
Yes I Did,Thanks Mudder..........
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-14-2007, 02:39 AM   #19
toomanytoyz
Luv the Crewcabs
Sorry about The Confusion, I Just Posted that as a Alternate Way to Correct the Geometry when you Put a Body Lift on..........
That Pic Posted was of a 89 Body Sitting on a 85 Frame, That is why the Offset Difference look's so Much in that Pic.............
Hope that Help's, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-14-2007, 02:46 AM   #20
toomanytoyz
Luv the Crewcabs
This Pic was From Mudder on Using a Ujoint Setup in His Conversion of his Truck, I Guess the Body Lift Caused the Steering to Have a Bind in it.......
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-14-2007, 07:58 AM   #21
Mudder
Mudder's Avatar
If you have a really good rag joint I think you could get by without the ujoint but there are chances it could bind up. Whenever a body lift is used the geometry of the shaft is changed.
Old 12-14-2007, 12:33 PM   #22
see ten
WTB this ad
see ten's Avatar
This isn't a 67-72 but the concept is near identical. The cab mounts were moved to the outside of the frame and used without a body lift. Of course the problem arises with the front of the frame dropping down. Body lift bushings/mounts were used under the core support to keep it up level with the rest of the cab.
This is another one I used to own that was done pretty close to the same way.
see ten is offline   Reply With Quote
Thread Tools
Display Modes
