12-01-2007, 12:15 AM | #1 |
Ease my Hub-Centric whoa's...
Well, I'm gonna get these turbines from a friend for free. But, they're from 'those other guys' and have a 5" opening. Hub-Centric GM wheels are roughly 4 5/8 (corrected me if I'm wrong). (I've also a Chrysler spare that has a 4 3/4 opening.)
Do the Ford hubs bear the weight, i.e. hubcentric, at that size (5")? I think that the hub sizes are roughly the same as GM? Thats how Ford/Dodge D60 axles can be used on our trucks. If not hub-centric, then the lugs must carry the weight. So then, why can't these safely be used on GM hubs? Or, is it more a matter of centering these wheels on a hub that is smaller than its' opening? These turbines have a flat lug nut surface. The Chrysler spare and GM spare (both steel) have beveled lug nut surfaces... I suppose these are for acorn style lug nuts? I just wanna use these wheels! Old Creek
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
12-01-2007, 12:30 AM | #2 | |
Bloo
Re: Ease my Hub-Centric whoa's...
if im not mistaken, the correct lug nuts for those have a shank that goes down into the lug hole, which carries the weight and centers the wheel. then the washer/nut holds it tight to the hub
like these:
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
12-01-2007, 02:35 PM | #3 |
And you can go into any big tire and wheel store, and ask them for 'hub centric rings'.
I had some custom made for running BMW wheels on my Firebird, and it took such a long time, they felt bad and gave em to me for free.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
12-02-2007, 12:51 AM | #4 |
hub-centric rings..... interesting!!!!
12-02-2007, 06:45 AM | #5 |
The lug nuts will center those wheels OK as long as you have the correct nuts with the right taper for the wheel.
Tim |
12-02-2007, 10:38 AM | #6 |
With an 8-lug wheel, I wouldn't sweat it at all. The shank of the nuts will center the wheel and 8 studs are plenty to hold it on.
12-03-2007, 07:15 AM | #7 |
They only ever sold custom wheels with a one size fits all center.We never gave it a second thought and I`ve never had a problem or know anyone who has with it.
12-03-2007, 09:16 AM | #8 |
Aluminum slot wheels rule...
Yeah, just bolt them up and be happy.
12-03-2007, 11:35 AM | #9 |
Yeah, the more reading I do on the web the more I find that the hub-centric wheels were mainly to CENTER the wheel on the hub, not to carry the weight. Other, 'lug-centric' wheels are centered by the lug nuts. Hub-centric rings are made with plastic, some aluminum. They are used to center the wheel. Don't know if the GM wheel was specifically manufactured to carry the weight.
I can't imagine a reasonable load snapping 8 lugs a side. For example, 8,000 lbs would be 500lbs on each lug.... I wouldn't think that would be enough to shear the lugs.
12-04-2007, 08:54 AM | #10 |
Junior Member
When you do bolt them up do NOT forget to retorque the bolts after a few hundred miles.
12-09-2007, 02:31 PM | #11 |
Most after market wheel have the center opening bigger than the hub, that is how the center cap fits. On an 8-lugger don't sweat it!! I'd love to have a set of those on my 07 dodge, except they need to be 17 in diameter to clear the brakes!
Thread Tools | |
Display Modes | |
