Old 12-01-2007, 01:03 AM   #1
biggreenchevy
biggreenchevy's Avatar
Question 203 shifting prob
Ive got th350 with a 203 t case on the back and its Pita to get it to shift from 2hi to 4hi most of the time
Ive got the part time convert in it now.
Ive put a longer shifter on it but it is still hard to shift.
I know 203 are notorius for this but what have you guys done to fix this
Ive switched back and forth on two stock shifters and its still the same
So do you guys think its in the shifter or the t case
and wat can I do to fix short of just getting a doubler from ord like i want to do(ive got a 205 to do it)!
biggreenchevy is offline   Reply With Quote
Old 12-01-2007, 01:15 AM   #2
Blue_71
Bloo
Blue_71's Avatar
Re: 203 shifting prob
i posted with a similar problem a couple months ago.
http://www.67-72chevytrucks.com/vboa...d.php?t=259943
this is just my farm truck though, so ive went ahead and left it in low... to me, its not worth the effort when i want to put a 4 speed in it anyway
is that your truck in your avatar? heres mine
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 12-01-2007, 01:33 AM   #3
biggreenchevy
Nice Truck Could be distant cousins possibly, Its green too you can barly tell tho
Old 12-01-2007, 01:50 AM   #4
Blue_71
Bloo
Blue_71's Avatar
believe it or not, that mud on mine is after TWO passes through the pond. it wouldnt spin and the ground was so hard from our lack or rain this summer (we were like 24 inches below normal), that there wasnt any mud. the mud was only as deep and the brown circle around the tire....
now after this rain weve had this week, im dying to go play!!
Old 12-02-2007, 10:42 AM   #5
LONGHAIR
Click the link from Blue_71 above. Cleaning and fresh lubrication are the keys to this. The slightest grit between the plates in the shifter housing will cause problems.
LONGHAIR is offline   Reply With Quote
Old 12-02-2007, 11:06 AM   #6
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
I know this is off topic, but is the NP 205 & 203 all gear drive? I havent owned one until now. The Dana 20 in my Blazer is all gear so I'm curious if the NP in my C/20 4 x 4 is the same - all gear?
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 12-02-2007, 04:12 PM   #7
hilbilly
I do everything twice, so what
hilbilly's Avatar
Location: To the Right. One may go as far to say WAY to the Right
the 203 is not, and it's a piece of chit
www.hilbillytruckpulling.com
hilbilly is offline   Reply With Quote
Old 12-02-2007, 10:43 PM   #8
biggreenchevy
why do you say that?
Ive had two of em and they've lasted thru alot of abuse including pulling the wheels of the ground its relentless in four lo, I would rather have a 205, 203 combo tho anyways. Only prob I got tho is the shifting geuss Ill pull it apart tommarow and clean it out.
thanks for the help guys
Old 12-02-2007, 11:54 PM   #9
1969k10stepside
NP205=Strong gear driven part time 4wd t-case.
NP203=Lighter chain driven full time 4wd t-case.
The t-case in your '70 should be a NP205 if its original..And btw they are called K20s,just thought I'd tell you so you can type that if you feel and not type out the longer version...
As for the 203s being "a piece of chit" Well,they definitely aren't anything like a NP205..full time 4wd unless a kit is added,chain driven,sucky shifter...I think they are way worse than a NP205 but if properly taken care of,it will be trouble-less..I rebuilt the t-case in my '79,put in a new chain even though the old was ok,but just did it so I might not have to later on...I put it in lo-loc about once a month to get the lube moving through it all and have never had any issues...Of course,I'm putting in a TH400/NP205 in '08 when I put the 454 in..
1969k10stepside is offline   Reply With Quote
Old 12-03-2007, 09:21 AM   #10
Old Chevy Mech
Keepin it runnin!
Thanks Guys, I was hoping the 205 was all gear and very relieved to hear it is. I do believe what i have in the Truck is stock and a 205 because it looks pretty darn big and its all cast casing.
Yer right, I thinkl I'll go with the 'K20" name it is shorter and it seems to be the lingo here, lol. I just get hung up on what the dang Emblems say..Maybe one day I'll get bored and take K-5 Emblems and replace the C with a K on mine! That'll mess with people's heads when they see it.
Frank
1970 K-5 4X4 Blazer
Old 12-03-2007, 05:54 PM   #11
biggreenchevy
I got er fixed
Now i can go see wat else i can tear up!
thanks for the help!
Old 12-03-2007, 10:37 PM   #12
Blue_71
Bloo
Blue_71's Avatar
glad to hear this fixed yours. if i dont convert mine to a 4 speed K20, ill fix mine too, lol
1989 Chevy K2500
Thread Tools
Display Modes
