Just Another Crazy Canuck
power for elec choke
will the old points distributor wire(yellow wire) supply enough power for and electric choke on a qjet?
I am running HEI and this wire is jsut hanging there taped off can I use it? Thx, Burlinator ![]() ![]() ![]()
1985 ![]() ![]() ![]() soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI |
I'll bet it will make it function, more or less. The problem is that wire is only going to supply around 9 volts. Your choke is made and calibrated for 12.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
eliminate the yellow wire, it ran from + at coil down to the R post on solenoid, and tape off the end of the white wire that also ran to + on the coil.
run you a new 14 guage wire from the batt terminal on HEi cap to the fuse panel wher eit says ign unfused(spade terminal), and run you an inine fuse around 15 or 20 amp, easycake good luck |
When I put the HEi on mine, it only had one yellow wire going to the coil that had 12 volts all the time (no white wire) I took the yellow wire off of the solenoid, the yellow wire that I took off of the coil still had 12 volts. I know it wasn't suppose to be like that, but?
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
I used that wire but I went back into the harness and cut off the "resister" wire and replaced with a 16 ga automotive wire. That original "resister"wire will give you a 12V reading until you put a load on it then it drops.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
Thread Tools | |
Display Modes | |
