Old 12-13-2007, 05:38 PM   #1
Sequoyah
so easy a caveman can do it...
Sequoyah's Avatar
A couple of questions before the back half of the truck is put together
Is there some sort of o ring, gasket, or something that goes in between the drain plug and the housing? There is about a 1/4"...maybe a little less of threads showing.
I was thinking about using some thredloc on all of the bolts. Are there some that it wouldn't be a good idea for? Is blue thredloc the one to use?
I have a re-print of the factory manual and it has all of the torque specs for all of the bolts. Should I just make a list of all of the specs, torque to that and then re-check after 100 miles? I believe the bolts at the front of the trailing arms call for 280 ft/lbs. I was talking to my neighbor who is more of a mechanic than me and he told me I didn't need a torque wrench that went that high and that he would set his impact to "kill" and that would be fine. I dunno about that...maybe I'm being too anal about things, but I've taken my time grinding, sanding, painting, buying quality parts and don't want things to go to crap cause I slammed it all together.
Is there anything else I'm forgetting?
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=242380
Sequoyah is offline   Reply With Quote
Old 12-13-2007, 06:03 PM   #2
cdowns
cdowns's Avatar
Re: A couple of questions before the back half of the truck is put together
from the factory that fill plug had a plastic tag on it thats the reason for the gap// believe the tag had gearoil specs
Old 12-14-2007, 04:21 AM   #3
Sequoyah
Sequoyah's Avatar
morning bump for some good advice
My build thread
Old 12-15-2007, 04:52 PM   #4
Sequoyah
Sequoyah's Avatar
o.k. one more bump and I'll let it die. Any info on the drainplug? Anything at all ? lol <----when is this appropriate to use in a thread?
My build thread
Old 12-15-2007, 10:06 PM   #5
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Picture of the red tag dif. tag.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Thread Tools
Display Modes
