Old 12-14-2007, 10:18 AM   #1
kszygc
Unhappy Annual o2 sensor replacement
Once a year or so I have to replace the downstream O2 sensors on a 99 Silverado. By that I mean the 2 sensors after the converter not the two before. It has the 5.3 w/ auto trans, auto 4x4. The previous owner cut the y-pipe and installed 2.25 inch pipe all the way to the rear without mufflers at all. I bolted on a pair of 4 inch supertrapps at the back end to cut down on my hearing loss, it's bad enough as it is. It has a K&N fitercharger kit and unknown brand of shorty headers. The computer is still stock though. I will get the DTC for low volst and no volts so I pull the sensor and it is in pieces internally. They aren't terribly expensive, I just get tired of replacing them. Anybody have any ideas or experience?
kszygc is offline   Reply With Quote
Old 12-15-2007, 09:06 PM   #2
get me on the road
No Matter What.
get me on the road's Avatar
Re: Annual o2 sensor replacement
So I'm guessing you have 2 pipes one on each side, from the maniflod to the rear. Correct? If it is then I would put the 2 new downstreams in, and feel how much vibration is around them, if there is alot that could explain the internal pieces being broke. To fix that you could tac a hanger close to each pipe leaveing room to R&R the o2s if they go bad in the future. If possible use those hangers that have rubber straps on them to allow movement.
Currently own:
89 Chevy Silverado
Previously Owned:Starting with my first vehicle
86 Mercury Cougar /89 Olds 88 /88 Chevy S-10 /84 Pontiac Firebird(I miss it) /91 Chevy S-10
get me on the road is offline   Reply With Quote
Old 12-16-2007, 11:05 AM   #3
G35MIKE
why not zip tie the o2 sensors somewhere else, and run o2 simulators? That's what I would do.
g35s (areo,premium,navi)
67' fleetside
G35MIKE is offline   Reply With Quote
Old 12-17-2007, 08:49 AM   #4
kszygc
I appreciate the replies and information. The additional structural mounting sounds like the way to go. Unfortuanatly, the downstream sensors are used for the OBDII system, and are required for emissions inspections each year. When I have a clearish day, I will crawl under the truck and inspect. Thanks again!
Old 12-17-2007, 10:53 AM   #5
spudz
spudz's Avatar
when I had my truck programmed, I had them turn off the rear o2 sensors.. So no matter what, the check engine light will never come on for them. Cost 150 bux to get it programed.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-19-2007, 08:53 AM   #6
G35MIKE
just wire the o2sim into the ecm, and leave the o2's in as dummies. That's what I did on my car, and passed smog with no problem.
67' fleetside
Thread Tools
Display Modes
