12-20-2007, 06:19 AM | #1 |
1986 c30 dually spindles...help
just wondering if anyone knows of a lift spindle (2wd) that will fit the 1986 c30 ? i want to get away from the dually front /rear wheels and go with regular 8 lug wheels..can i use the spindle off a c20? just want a moderate lift 2-4 inch to fit some tires under this thing without rubbing...how about the 1988 and and up spindles? just wondering what my options are here...thanks in advance for your advice...
tom |
12-20-2007, 06:43 AM | #2 |
One shot, one kill.
Re: 1986 c30 dually spindles...help
Tom: I don't think spindle from C20 will work. Ball joint issues. Stock spindles from any other 30 series truck will be the same as far as riding height is concerned. If you only want to lift her up a couple of inches get heavier springs. Tell the parts guy what you want and he should be able to help you. Don't be fooled by what appears to be a spring of the same height. look at the wire diameter of the spring, it will be larger than what you have now. This increase in wire diameter will prevent the truck from droping as far as before BUT, it will also stiffen the ride. You WILL know your driving a truck, LOL, it's going to get STIFF!! Hope this helps, Jim
12-20-2007, 08:04 AM | #3 |
you can chainge the front hub and diskbrakesetup from the C30 for the single wheel C30 van setup the dualy type hub is a diskbrake hub combo , the van type has a seperate disk on the hub itself you might have to chainge the bearings too .
it brings the normal wheels back under the fenders , the eaziest way would be to chainge the rearaxle as one unit cause it has different brakes and isnt as wide as a single wheel unit and these van units might be geared better as whell
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
12-20-2007, 08:43 AM | #4 |
There are no lift spindles available for 73-87s currently, and if you have a diesel or a Big Block there arent any heavy springs available. If you have a small block though then the BB or diesel coils should provide some lift. As far as 88-98 spindles they can be made to fit. There is an article on swapping stock 88-98 spindles to a 67-72 truck, the front suspensions on the 73-87s are fairly identical to 67-72s. I have never swapped the 88-98 spindles but certainly thought about it when I had my 82 chevy.
As far as getting rid of the dually you could run Hummer bead lock wheels. They will bring the tires in due to the stock offset of the wheels.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
12-20-2007, 11:54 AM | #5 |
thanks for all the replies...prerunner1982,do you know what it would take to fit the 88-98 spindles on the 86? like arms and all or just spindles??
thanks,tom |
12-21-2007, 11:11 AM | #6 |
I tried to search for it but the search button isnt currently working for me. If you can get it to work you might do a search for 88-98 spindle in the 67-72 truck section.
12-22-2007, 05:11 AM | #7 |
Professional Beer Tester
Tom, I have been told by several people that 73-87 2WD C30 spindles are the same, whether single wheel or dual wheel. Supposedly the rotors can be swapped out using the same spindle and brake caliper. While I cannot confirm this yet, I hope to be finding out for sure soon. I have an 82 dually parts truck, and I would like to use the dually bed, rear end and rotors(or whatever it takes) to convert my 90 R3500 single wheel Crew Cab(73-87 body style) to a dually. Please let us know if you find out before I do. Thanks.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
Thread Tools | |
Display Modes | |
