12-22-2007, 02:52 AM | #1 |
The oddest Todd around
Power steering pump bracket
I'm pulling the 350 out of my c10 to replace it, and I noticed that my power steering pump's bracket attaches to the bloody motor mount.
Is there a different bracket that I can use that doesn't attach there, but still puts the power steering pump in that location? Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
12-22-2007, 03:22 AM | #2 |
Re: Power steering pump bracket
I'm looking for the type that only connects to the front of the block and doesn't wrap around, but still leaves my alternator where it is.
12-22-2007, 03:39 AM | #3 |
Like this? |
12-22-2007, 03:47 AM | #4 |
The vans used a bracket that attatched to the front exhaust manifold bolt. The front cast bracket is the same as our trucks.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
12-22-2007, 04:04 AM | #5 |
I have long tube headers... so that's no good either.
I'm looking for one that doesn't attach in the back at all... does that not exist?
12-22-2007, 04:30 AM | #6 |
Java Mechanic
I'll watch this for idea because I'll be there soon but...
In my wayward youth I had a 72 Camaro with a 350 and headers that had a bracket very similar to the one in the pic. I located a long shank bolt of the same size as the header bolts and used a socket and some washers as spacers so I could retain the factory P/S and alternator brackets.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
12-22-2007, 04:32 AM | #7 |
I don't know how much money you want to spend; but you might check out www.alangrovecomponents.com website and see if they have one to fit your application. Just a thought.
Ron
1972 C30 Cheyenne Super 1971 C10 (Parts truck) |
12-22-2007, 05:04 AM | #8 |
Location: Sunny, Florida, some might call it South Alabama
the one that i have my dad actually just took a piece of 1/4 inch thick medal measured it and we put a spacer on the back of it. also drilled the inside out so it would have room to adjust a little
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
12-22-2007, 12:18 PM | #9 |
Doesn't having the power steering pump bolted to the exhaust manifold get in the way of the alternator?
Todd
12-22-2007, 12:33 PM | #10 |
You can slot the one you have and that makes it a little easier to get back in place. I'm assuming here and I know what that usually means.
12-22-2007, 12:58 PM | #11 |
Msgt USAF Ret
Todd is this what you have? Do you have a long or short water pump. The brackets are different.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12-22-2007, 06:37 PM | #12 |
Yes, that is the one I have. And I have the short one I think. There is no space between the water pump and the timing cover.
12-23-2007, 02:18 AM | #13 |
How about this style, it cradles the pump with one pivot bolt in the front, then mounts up with a bracket to the cylinder head and the first bolt on the exhaust manifold.
I can take more pics. if this is of any help...J
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-23-2007, 03:47 AM | #14 |
There is a guy here in Bend that makes a kit. I got one they are slick. Bolts to the front two holes in the block.
12-23-2007, 04:25 AM | #15 |
I used the March bracket; they have other low-mount items that work with a drivers-side mounted alternator. http://www.marchperf.com/
http://67-72chevytrucks.com/vboard/s...g+pump+bracket |
Thread Tools | |
Display Modes | |
