12-29-2007, 09:42 AM | #1 |
HERE.......Somewhere
Heater hose???
I need a heater hose that will have a very tight fit. I got one but it falls off I hit a bump or turn the heater wide open.
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
12-29-2007, 10:37 AM | #2 |
Re: Heater hose???
Sounds like you need a hose clamp on it.
68 C-10 Custom LWB 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
12-29-2007, 11:15 AM | #3 |
Re: Heater hose???
The heaters on these trucks use two different size hoses. One is 3/4" and the other is ????. Somebody else probably knows this one.
Robert Member 1532 |
12-29-2007, 11:19 AM | #4 |
I miss this truck.
Re: Heater hose???
If turning the heater wide open causes it to fall off, then you are probably refereing to the ducts under the dash, not the water hose under the hood, right?
If so, then go to O'reilly (Advance didn't have it, don't know about autozone) and ask for 2-1/4" Defrost duct. Nice tight fit, easy to install, total cost: $3.50.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
12-29-2007, 11:49 AM | #5 |
Old Skool Club
Re: Heater hose???
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-29-2007, 12:36 PM | #6 |
Re: Heater hose???
or large zip ties work well too.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
12-29-2007, 12:41 PM | #7 |
its all about the +6 inches
Re: Heater hose???
zip ties and hose clamps are the best way to go
12-29-2007, 12:57 PM | #8 |
Re: Heater hose???
ziptie em and they wont come off no more
12-29-2007, 01:47 PM | #9 |
Re: Heater hose???
It's in the cab, I used those quick ties and it don't work. So im guessing I need hose clamps.
12-29-2007, 02:24 PM | #10 |
Re: Heater hose???
ha. im think 'n this cat has got antifreeze all over the place....you can order the hoses from brothser or lmc an they fit real tight..or they did for me..good luck an stay warm.
12-29-2007, 02:34 PM | #11 |
Re: Heater hose???
I got one at autozone and its the one thats on it right now. Is there a place that has them like napa, advance, or carquest.
12-30-2007, 02:00 AM | #12 |
Re: Heater hose???
The old ones get brittle,stiff,and shrink up to where they wont stay on.They just need replaced.
The one you bought at Autozone,was it made for your truck or just a length that was cut?Is it too short or does it just fit too loose?If it`s too loose try a little weatherstrip adhesive along with a zip-tie,if the zip-tie isn`t holding it. Are you and that redhead out fogging up the glass?tisk tisk tisk...
12-30-2007, 06:34 AM | #13 | |
Re: Heater hose???
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! Last edited by 70' GMC; 12-30-2007 at 07:36 AM. |
12-30-2007, 07:53 AM | #14 |
I miss this truck.
Re: Heater hose???
It comes in a tube, like gasket sealant. I'd probably still just go buy the $3.50 duct I suggested earier. I'm guessing you probably bought 2-1/2" instead of the 2-1/4"
12-30-2007, 07:07 PM | #15 |
Re: Heater hose???
Tynee can I get the 2-1/4 hose at autozone, besides the catalogue???
12-31-2007, 01:19 AM | #16 |
Re: Heater hose???
Ask Autozone what they can do.Hopefully they`ll know the answer.
12-31-2007, 01:24 AM | #17 |
blood type; Retumbo
Re: Heater hose???
can someone please take his hand and guide him to the store to get what he needs?
12-31-2007, 07:53 AM | #18 | |
I miss this truck.
Re: Heater hose???
70' GMC. As stated above, either stop in or call your local Autozone, ask for 2-1/4" defrost duct. They'll be able to tell you if they have it. Like I said, I got mine at O'reilly's.
Thread Tools | |
Display Modes | |
