![]() Join Date: Nov 2005
Cut Frame or Swap Parts to Short Frame?
I have a 67 GMC long bed with rear Leaf Springs and a good 69 chevy SWB frame. Was thinking about swaping the cab and front clip from the 67 then thought about simply cutting the frame to make the SWB truck I want.
Would there be any benifits to having a SWB rear leaf spring truck over a factory Coil rear end. Which would be easier, anyone done both? neither have engines in them at the moment and both are rollers. Thoughts?
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale Last edited by 67Mach1; 12-30-2007 at 10:09 AM. |
Re: Cut Frame or Swap Parts to Short Frame?
I prefer the coil spring setup myself. I'd swap everything over.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
No brainer... I'd swap as well. You will have a coil truck (more desirable) as well as an uncut frame. It will be worth more if you ever decide to sell as well being coil/uncut.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
I'd swap the body over.But if you wanted the leaf springs you could swap the suspension over,The frames are the same between a leaf and coil spring 2wd truck.
![]() Join Date: Dec 2007
Hi 67mach1,
There are some things to consider when dealing with leaf over coil suspension, for example you can intall wider tires on springs than on leafs. etc. etc Early classics has a link that details them. Enjoy! http://www.earlyclassic.com/Tech.asp...=Spring%20Time |
I'd say swap to the 69 SWB frame w/coils as well. You'll have a better ride. Plus you'll be able to sell the LWB roller frame to someone who needs it.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
![]() ![]() Join Date: Jul 2002
Do the swap....then turn the LWB leaf frame into a trailor to tow behind the SWB.
#8 | |
Guessing I should invest in new body to cab and radiator bushings....
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale Last edited by 67Mach1; 12-30-2007 at 04:03 PM. |
I am a Referee of life.
Make sure you get the proper radiator mounts.They are different between 67-68 and the later ones.If you use the wrong mounts there will be alignment issues with the front clip.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Thread Tools | |
Display Modes | |
