Old 01-01-2008, 04:33 PM   #1
bighead
350 Chevy Short Block
This is a 350 I was building for my truck project. I'm going to go in a different direction with this project and would like to sell this engine. It's a 350 four bolt main block that was cleaned and bored .020 over. The stock rods were resized and fitted with aftermarket rod bolts and new Sealed Power hypereutetic pistons pressed on. The pistons have a small 1/8th inch dome that gives around 9.5-1 compression with open chamber heads and have new moly rings. The cast crank was turned .010 on the mains and .010 on the rods. The rod, main, and cam bearings are all new Clevites. There is a new Melling oil pump, pick up, pump shaft, and oil pan included all in there boxes. There is also a new Clevite brand camshaft with specs similar to a High Energy cam, a Cloyes timing set, and Sealed Power lifters. The unused but opened Felpro gasket set is also included. $1000, sorry can't ship this one.
bighead is offline   Reply With Quote
Old 01-02-2008, 04:01 AM   #2
bighead
Re: 350 Chevy Short Block
bump
Old 01-03-2008, 03:33 AM   #3
bighead
another bump
Old 01-03-2008, 10:13 AM   #4
72highlander
Sophomore Member
72highlander's Avatar
do you need any parts as trade?
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 01-03-2008, 10:59 AM   #5
bighead
Maybe a pair of light weight wheels like Centerlines or welds in 15x10 size. Also a nice or repop 67 rt. front fender. big
Old 01-03-2008, 02:57 PM   #6
72highlander
Sophomore Member
don't have those. i have a very nice long bed, a nice 68 cab and doors, a short 71 frame, a nice core support, a nice short floor blasted and primed, but has a hole where a salt block sat and went through that would need patched, an nos short left bedside, an nos set of short 69-72 lower black mouldings, nice blue headliner and sunvisors, if any of this is something you could use let me know.
Old 01-03-2008, 03:53 PM   #7
Billla
Billla's Avatar
TTT as it looks like a good buy for someone!
There's no such thing as "open chamber" SBC heads - what cc head is required to give 9.5:1 (assuming 76cc?)
Billla is offline   Reply With Quote
Old 01-03-2008, 05:43 PM   #8
bighead
Yes, 76cc heads. Meant to say low compression heads. I've got big blocks on the brain.
Old 01-03-2008, 05:45 PM   #9
bighead
Sorry Highlander, don't see anything I'm in need of right now.
Old 01-03-2008, 05:55 PM   #10
72highlander
Sophomore Member
no biggie, mines original motor and runs great, i'm eventually gonna find one and pull original to build back stock for when my son is ready to drive it.
Old 01-04-2008, 04:32 PM   #11
bighead
How about $900???
Old 01-06-2008, 02:11 PM   #12
bucky_21_7
bucky_21_7's Avatar
i like i like
bucky_21_7 is offline   Reply With Quote
Thread Tools
Display Modes
