Old 01-02-2008, 12:06 AM   #1
hewlett2002000
hewlett2002000's Avatar
disc brake rear end....
what if any disc brake rear ends will bolt up to my 66? i know they make kits but there a bit pricey... for me at least. lol
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 01-02-2008, 04:20 AM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: disc brake rear end....
Well, you can always find some rotors that will fit over your axles...then use weld on caliper mounts.
That wouldn't be too bad.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-02-2008, 04:54 AM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-02-2008, 05:30 AM   #4
PrerunnerRob
PrerunnerRob's Avatar
I've looked into this too, and the most expensive part is the calipers. I think they were from a 76-79 Caddy, and around $250.
PrerunnerRob is offline   Reply With Quote
Old 01-02-2008, 05:35 AM   #5
protrash64
Resistance is Futile
protrash64's Avatar
I have seen one truck locally that had a complete swap from a '99 and up GM truck.........6-lug baby! Its a bit wider than the old stuff so backspacing becomes an issue.......also the lug threads are metric. It sure looked nice, however.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-02-2008, 05:37 AM   #6
poorboy
poorboy's Avatar
When I get to that point I was going to try 4wd rotors with the weld on mounts.
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 01-02-2008, 06:05 AM   #7
62 short step
62 short step's Avatar
My buddy gave me a complete kit from his 98 z71. It came from one of the popular disc conversion companies, I forget the name.I have an 89 blazer 4x4 axle under my 61 4x4. I'm hopeing it will just bolt up. I agree with the above mentioned weld on some caliper mounts.
62 short step is offline   Reply With Quote
Old 01-02-2008, 12:50 PM   #8
Tomsriv
Tomsriv's Avatar
I got my kit from CCP. It was only a couple hundred dollars more for four wheel than the front wheel disc brake kit. The pain in the butt is rerouting the brake lines and the parking brake. My kit also came with the proper master cylinder for use with 4 wheel discs. Otherwise you will need to get a WilWood adjustable proportioning valve. The rear brakes are off an 80-85 Cadillac Seville.
Tomsriv is offline   Reply With Quote
Old 01-02-2008, 01:31 PM   #9
ElkyRacer
Ok, better yet, anyone have the measurements off of a stock rear end? Wheel mounting surface to wheel mounting surface (wms-wms)? Im about to see what I can find to slap under my 64 when I swap out the front for 5 lug stuff, if I can even find a bit narrower rear end, that would be great!
Kyle
ElkyRacer is offline   Reply With Quote
Thread Tools
Display Modes
