Old 01-04-2008, 02:58 PM   #1
jlaird
jlaird's Avatar
steering box lube
I have a manual steering box out of the truck I am cleaning up to paint. What kind of lube goes in this? The service manual says "water resistant EP Chassis Grease." Is this just regular grease you would put in suspension parts?
I also noticed as I turn the input shaft with my hand, it turns smoothly until you get to one "end" of the full cycle and then you can kind of feel it "grabing," and doesn't turn as smooth. Is this anything to worry about? Maybe the adjusting screw needs to be turned?
jlaird is offline   Reply With Quote
Old 01-05-2008, 09:22 AM   #2
jlaird
jlaird's Avatar
Re: steering box lube
anybody?
Old 01-05-2008, 09:35 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If it says "chassis", then I would use the same grease that you'd lubricate your chassis with.
As for your second question, I'd wait until it is lubricated, then repeat the test you made. If greasing the box doesn't solve your delimna, then you'd have to delve further into the issue. I'm gonna hazard a guess that it needs lubricated, and that is why it's puzzling to you.
Member Nr. 2770
Old 01-05-2008, 11:54 AM   #4
airdale94
airdale94's Avatar
EP is extreme pressure. As far as the water resistant I would think most all are. NAPA has some extreme pressure wheel bearing grease. How do you fill it does it have a zerk. I don't know but if I was to guess I would have thought it would have taken gear oil.
I think most gear boxes "load up" at the end of their travel.
airdale94 is offline   Reply With Quote
Thread Tools
Display Modes
