01-04-2008, 03:46 PM | #1 |
www.73-87chevytrucks.com
Silverado Kick Panel Speaker pods coming soon
I got these in today. This is the test mold I am going to check it against my trucks and once tested they should be online for sale. They are designed to mount in the recessed area of the original panel as pictured. Let me know what you think...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
01-04-2008, 03:48 PM | #2 |
It followed me home?
Re: Silverado Kick Panel Speaker pods coming soon
any idea on cost?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-04-2008, 04:02 PM | #3 |
They haven't gotten a price on them. I just knew there was a demand and had them make them. They should be inline with our current offereing though. Once we get them fitted I will post the pricing/link to the catalog...
01-04-2008, 04:09 PM | #4 |
01-04-2008, 04:23 PM | #5 |
Moderator
In other words, YES!!!!!!!!!!!!!!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
01-04-2008, 05:02 PM | #6 |
yeller
Chris, a couple questions?
1. Why are these called Silverado kick panels...and what is the difference between a Silverado kick panel and a non-Silverado kick panel? Do only Silverado's have kick panels...hence the name? 2. What is the difference between these and the Roddoors speaker pods, they look very similar?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
01-04-2008, 05:22 PM | #7 |
81-91 Silverado panels are full panels that go to the floor, all of them had this. What I am calling non-Silverado panels only have half a panel and the Rod Door piece work fine on them - 73-80. These are the same as the Rod Door a for as the speaker section goes since Rod Doors is making them for me, except they mount in the recess of the original panel.
Need a pic for comparison?
01-04-2008, 05:44 PM | #8 |
yeller
Nope, that makes sense...thanks for the explaination.
01-04-2008, 07:14 PM | #9 |
very cool! i made same thing out of fiberglass couple years ago, but need to be redone as the e-brake pedal hits the pod. also want to get 6" to replace the 5.25's. these will be my best option time wise.
01-04-2008, 07:46 PM | #10 |
What size speaker will fit in the panels. Look like 5 1/4" to me. Have any diameter and depth measurements?
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
01-04-2008, 07:49 PM | #11 |
01-05-2008, 06:00 AM | #12 |
Same as the originals, 6.5" There is a slight modification they will have to make to them the drivers side needs a hair of adjustment to clear the bottom of the E-brake (like 3/16") and the front leading edge needs to be flattened on the passenger side and drivers side..
01-05-2008, 08:57 AM | #13 | |
My long term goal is to dress my truck up a little at a time. I have an non-air 85 Custom Deluxe LB. The kick panels in my truck do not come all the way down to the floor. I understand your speaker mounts fit the Silverado equiped truck with the longer style kick panels. First will the longer Silverado kick panels fit my truck no modification? And your speaker mounts will fit on the longer Silverado kick panels right? I have only had my truck 2 months and wished I had got a truck a long time ago. It is much more fun to work on than a car! Last edited by 87Bob; 01-05-2008 at 08:58 AM. |
01-05-2008, 01:12 PM | #14 | |
We already have the non-Silverado panels for sale that will go to the floor...
01-05-2008, 04:47 PM | #15 |
Spear and magic helmet!
Nice!
01-08-2008, 06:23 AM | #16 |
I could of used them a couple months back. No one seemed to make them so i made my own. Very similar.
Mexican |
01-08-2008, 06:44 AM | #17 |
ROCK*STAR
01-08-2008, 11:01 AM | #18 |
The drivers side has the same speaker angle and the e-brake does hit. I never use the e-brake, and i wanted it to have the same angle as the other side. If i would of wanted the clearance for the e-brake i would of used a smaller speaker or changed the angle of the speaker which i didn't like. I had them speakers laying around so i used what i had. I'm thinking about getting some 5 1/4" 3-ways and making another set.
Mexican |
01-20-2008, 05:56 AM | #19 |
Real Projects never die
bump...any status?
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
01-21-2008, 09:34 AM | #20 |
Got them test fitted and sent them back with some adjustments...
06-18-2008, 07:10 PM | #21 |
Ok, I got the last iteration of these this past week. They will require some trimming to get the to fit perfectly since they are cut out of a mold, but in less than 20 minutes of trimming both were put into place. They are just "popped" in there with nothing holding them, just wanted to show what they look like installed.
They should be in the catalog this weekend.
06-18-2008, 07:45 PM | #22 |
very nice..any other colours or just black?
79 GMC Sierra 5.9 cummins, nv4500 |
06-18-2008, 08:30 PM | #23 |
Black only.
06-19-2008, 12:12 PM | #24 |
Nice, I'll be needing some of those. for you guys with speakers that hit the e-brake, why not modify the brake pedal?
06-19-2008, 06:17 PM | #25 |
A lot of them don't like having to do that....
Thread Tools | |
Display Modes | |
