Old 01-05-2008, 07:00 AM   #1
Psycho71
Psycho71's Avatar
Wiper Motor ?
I'm relocating the switches for my wiper motor, and headlights. I have the headlight part figured out. My question is... Regarding the two speeds on the motor itself... Are the low/high speeds built in to the motor (different taps on the windings), or does the switch control the voltage, thus the speed (like a rheostat)?
Thanks for any info you can provide. I'm at work, and trying to get a parts order in today. So I can't very well run this info down on the motor, or switch, right now. Except for asking here, of course.
Thanks again,
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-05-2008, 07:08 AM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Wiper Motor ?
Different taps on the windings...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-05-2008, 07:18 AM   #3
Psycho71
Psycho71's Avatar
Re: Wiper Motor ?
Thanks for the quick reply. Just what I needed to know.
Jay
Old 01-05-2008, 10:51 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Wiper Motor ?
iirc, The wiper switch provides the ground in the circuit(why the motor is mounted on rubber boots) for each of the internal winding(L-H) plus the squirter.
sneakysnake is offline   Reply With Quote
Old 01-05-2008, 06:22 PM   #5
Psycho71
Psycho71's Avatar
Re: Wiper Motor ?
I should be able to find out which wire is which with an ohm meter and some trial and error. My main question was applicable to what type of switch I need to buy.
But I'm glad you posted that info, it's definitely good to know before I get out there and spend a few hours scratching my head. Thanks for the heads up.
Jay
Thread Tools
Display Modes
