Old 01-05-2008, 03:06 PM   #1
mtburg71
mtburg71's Avatar
Need help with part to order
Ok, here is the deal. I have a 64 GMC. I am doing a disc brake conversion using a 71 Upper and Lower Control arm. My question is this, I would like to replace my outer tie rod end, but which one should I order, the one for the 64 or the one for the 71. Thanks in advance for any and all help.
Mike
1964 GMC SWBFS
2005 Dodge Magnum RT
mtburg71 is offline   Reply With Quote
Old 01-05-2008, 03:11 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Need help with part to order
Depends on the spindle, I think. I know 65 and 64 suspension have different ties. The parts guy I talked to knew and asked me if it was long or short(tierod). This was years ago however............maybe you should buy all of 'em!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-05-2008, 03:18 PM   #3
PrerunnerRob
PrerunnerRob's Avatar
You will need the one for whatever year spindle you are using.
PrerunnerRob is offline   Reply With Quote
Old 01-05-2008, 03:46 PM   #4
mtburg71
mtburg71's Avatar
If I order the 71 tie rod to fit the 71 spindle, will it fit the 64 adjuster sleeve? Thanks
1964 GMC SWBFS
Old 01-05-2008, 07:08 PM   #5
PrerunnerRob
I'm not too sure on that one, I would guess that the spindle taper would be the only difference. You could go to the parts store and try to see what fits maybe?
Old 01-06-2008, 03:36 PM   #6
mtburg71
mtburg71's Avatar
Thanks for the input guys, I believe I got it all figured out, please let me know if I am wrong. So today I had the opportunity to take the 71 disc spindle and put it on the truck to fit the 64 outer tie rod and it seems to fit okay, plenty of threads showing and the cotter pin hole. Am I missing anything? Thanks again.
Mike
1964 GMC SWBFS
Old 01-07-2008, 08:33 PM   #7
badriand
badriand's Avatar
Not sure on the 71 but i used an 87 suburban and got an adjusting sleeve adapter from cpp and then i had to flop the stock outer joints to the inside to make it work.
badriand is offline   Reply With Quote
Thread Tools
Display Modes
