Old 01-09-2008, 05:04 PM   #1
David Flores
David Flores's Avatar
What headers fit?
What headers are you guys using on your trucks?
Trying to figure out what will fit.
Oh, and I'm running a small block with floor shift auto.
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 01-09-2008, 05:31 PM   #2
Ogilthorpe
Ogilthorpe's Avatar
Re: What headers fit?
I'm running these headers (in ceramic)...
http://cgi.ebay.com/ebaymotors/CAMAR...mZ260200849073
they're a bargain - they fit great and outstanding quality, the flanges are stout on these things
Ogilthorpe is offline   Reply With Quote
Old 01-09-2008, 06:47 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Hey David, I used a Summit part that worked well. For 88-98 trucks. Welded the o2 hole shut and put them in.........my engine is in the forward postion which tightens it up a bit.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-09-2008, 07:22 PM   #4
David Flores
Do you happen to have the part number?
66 c10 swbfs
My Build.
Old 01-10-2008, 12:48 PM   #5
merlin65
merlin65's Avatar
I am using ramhorns, I lowered my truck so much that the aftermarket headers were going to drag the ground. So I had to get some ramhorns that dumped straight down so to clear my z bar. The ones that emptied out toward the back would not fit because of the z bar.
merlin65 is offline   Reply With Quote
Old 01-10-2008, 12:52 PM   #6
badriand
badriand's Avatar
First thing i did was jerk my headers off and put ram horns on. Get you a good set or it will sound like a cat hissing and spitting at ya. Also no way i could lower my truck much with the headers that were on it.
badriand is offline   Reply With Quote
Old 01-10-2008, 02:29 PM   #7
protrash64
protrash64's Avatar
Hey David............I had to dig to find the part number. It is as follows: SUM-G9014. These are shorty headers and you send your exhaust over the tranny x-member. Not one piece of exhaust can hit the ground. Check 'em out anyway. Oh yeah, these turned out to be Pacesetters.
Old 01-11-2008, 09:10 AM   #8
MikeN
MikeN's Avatar
On my 64 C10 with 350, I use the Hookers that are listed for a 64 C10 with 283 V8 and 3-speed manual. They fit like a glove. The only thing I had to modify was to shorten the threaded rod that actuates the clutch fork. I think they were $159 from Summit. From looking at the photos, I do not think ProTrash's headers will work with a manual transmission...no room for clutch linkage/z-bar.
MikeN is offline   Reply With Quote
Old 01-11-2008, 09:21 AM   #9
MikeN
MikeN's Avatar
I looked at the photos, Ogilthorpe's headers aren't going to work around the clutch linkage either. The only header I know of that works in a 60-66 with manual transmission is the Hooker HOK-2452HKR, $185.95 at Summit. Hopefully this link will work...
http://store.summitracing.com/partde...5&autoview=sku
Old 01-11-2008, 09:43 AM   #10
David Flores
I'm running a floor shift auto, sorry for the confusion.
I will not have to worry about any linkage problems.
66 c10 swbfs
My Build.
Old 01-11-2008, 02:49 PM   #11
pat66
pat66's Avatar
I have a set of hooker #2452They exit about 2"below the frame,pipes feed under auto trans crossmember.Dont know how low your goin.Used 7 angled and 1 straight plug wire,witch wasn't a big deal.Everything else cleared fine
02 Blazer
66 lwb step
66 lwb feet :flagw
Working to live not living to work
RIP RS
pat66 is offline   Reply With Quote
Old 01-12-2008, 12:46 AM   #12
blackedoutharley
I installed these exact same headers on my truck many years ago and after some minor issues they are not ready for replacement (13 years and 110K+ miles). First thing was I had to dimple a few pipes to make room for the clutch linkage... Also ended up cutting the flanges between the head pipes due to warpage... This, along with Fel-Pro header gaskets solved the leaking issues.. Also went from the 3/4" bolts to 1" bolts to get more thread engagement which stopped the bolts from backing off.... remember also that these headers have a 2.5" collector vs. the normal 3.0" found on most other headers.
Given that I am about to replace mine when the motor is out I am looking at the Hedmans or ones from Thorley as they are a better quality than the old Hookers... I have a set of ram horns but am concerned how they will flow on my stroker after it gets a refreshening....
YMMV
p.s. this is on a '65 C-10 LWB with a small block and the factory SM420 trans. I will have to check what position the motor mounts are in but I believe it is forward as well as I have no clearance issues with the HEI but there isnt much room..
Edit: just went and had a look and the motor mounts are bolted into the rear most holes on the frame rails... I actually have a ground strap bolted into the forward hold which may explain the closeness of the HEI to the firewall.. I think this is the only way to do it as the bell housing works like a crossmember given that there isn't one at the tailshaft..
Last edited by blackedoutharley; 01-12-2008 at 01:11 PM. Reason: more info on engine positioning...
blackedoutharley is offline   Reply With Quote
Old 01-16-2008, 11:21 AM   #13
Hillbilly Deluxe 65
Wheelin' and Dealin'
Hillbilly Deluxe 65's Avatar
http://www.ecklerstrucks.com/product...dept%5Fid=2203
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside
Porterbuilt Extreme front and rear
12bolt w/ eaton tru-trac 4:11 gears
1BADD65
my build thread:
http://67-72chevytrucks.com/vboard/s...=1#post2601700
Hillbilly Deluxe 65 is offline   Reply With Quote
Old 01-16-2008, 12:17 PM   #14
harbourmicah
harbourmicah's Avatar
im using the hooker long tubes like a few are also, they fit well
1966 chevy short step- under construction
http://www.fquick.com/harbourmicah
harbourmicah is offline   Reply With Quote
Old 01-16-2008, 01:20 PM   #15
jchav62
1962 C-10
jchav62's Avatar
I'm running a set of Heddman ceramic coated hedders. If you cruise their site, I believe they list a set for 60-66's. They are the ones I have..
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Thread Tools
Display Modes
