Old 01-16-2008, 05:43 PM   #1
cj66c10
Throttle Cable?
What are you running on your truck for a throttle cable/linkage. Mine has some rigged up toilet chain/cable junk that sticks.... I bought a Lokar cable, but it looks like I will have to change the gas pedal assembly out to make it work.
thanks,
CJ
cj66c10 is offline   Reply With Quote
Old 01-16-2008, 07:17 PM   #2
badriand
badriand's Avatar
Re: Throttle Cable?
Is it the stock pedal and linkage? Just missing the rod from the pedal to the carb? Mine had a brazing welding rod stuck in between them. I couldn't find anything so i made one. I just went to the hardware store and bought a small non threaded dow rod and used a dye to thread and bend it to the angles i needed. I also used a threaded coupler between them to adjust the slack. Works well. Ignore the rigging on the transmission detent cable had to use those to take out some slack.
badriand is offline   Reply With Quote
Old 01-17-2008, 07:28 AM   #3
slepysal
slepysal's Avatar
Re: Throttle Cable?
I am running an after market cable assembly,and pedal. You can get Lokar it is topof the line. I went with Spectere and it works just as well
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-17-2008, 12:41 PM   #4
62 short step
62 short step's Avatar
Re: Throttle Cable?
I have the Lokar cable and the Eliminater pedal. I really don't care for it, it seemed the stock set up worked better. Anyway, thats just my 2 cents.
62 short step is offline   Reply With Quote
Thread Tools
Display Modes
