I actually already own a couple of manuals on how to do this, my real question is... do I really need to remove the vent window assembly first just to remove the main side window? Has anyone done this before?
Also, I'm replacing the window trim and felt... does this require any special spray, glue, epoxy, etc. other than the kit itself that I bought from online? I'd like to get all my materials upfront before I'm mid-way through and realize, I need to make a run to my local Auto-Zone.
'72 Super Cheyenne LWB
Re: How Do I Replace My Side Window?
I was wondering that myself, because I have to do the same thing, but I'm afraid the answer is probably so. Otherwise, the window won't come out of the tracks because one of the tracks is the vent window. They are a real PITA to take out and put in, trust me.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
![]() Join Date: Jan 2007
From what I have seen - vent window comes out...
Here is a run-down on how to get that far... http://www.67-72chevytrucks.com/vboa...d.php?t=157539 Hope that helps! |
Active Member
Something else that will help, you can take the 3 screws out of the back track, push the main window back some, and gain some much needed space to work with the vent window frames. After reading some about removing the vent windows, it turned out to be not nearly as bad as I was expecting. Another tip is to cover any nearby painted areas of the door with blue painters tape, to help protect it from scratching.
![]() Join Date: Sep 2006
I've done a couple. All I remember is that it's like a big puzzle you have to figure it out as you go. But yes, the vent needs to come out and as was said loosen that back track. I know that part until after I did mine. It will help alot.
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
#6 | |
Out of the carpool lane.
![]() I had a really difficult time with mine and was seriously considering driving my truck off a cliff until I discovered this. I ruined several sets of window tint and valuable time before I figured it out.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#7 | |
And thanks everyone else for the 2cents of advice... it'll come in handy when I get started this weekend! ![]()
remove the vent,roll the window all the way up and slide it off the regulator,about 10 min
![]() Ok nobody warned me that the window is permanently attached to a metal track. How do I remove the window from the track without bending the track all to crap? And how do I put my new window onto the track? What special rubber, seal, epoxy do I need to use to make it stay?
Knock it off with a flat steel,clean the channel and take it to a glass shop to get the rite rubber to put it back,unless u saved it (i doubt it)
then use a rubber malett to knock it back on,(go slow)make sure u put it back the same way u took it off,u can write on the glass with a magic marker bob |
#11 | |
454 MAKES IT ROAR
Can't help with the window question, but did do all my felts and division bars, no glue needed just push fit real clean and easy, though the old division bar felt doe's need cutting out. Good luck with the rest.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
#12 | |
So there's no glue or seal? It's just wedged tightly between a rubber channel? What's a flat steel? Can I use a large flathead screwdriver?
Thread Tools | |
Display Modes | |
