Old 02-02-2008, 02:47 PM   #1
70stroker
70stroker's Avatar
cab sealer question
What do you use to seal up between the drip rail and the cab. Looks like silicone or body filler? Mines crackin and starting leak a little, would like to scrap it out and re do it. thanks
70stroker is offline   Reply With Quote
Old 02-02-2008, 03:07 PM   #2
TravisH
TravisH's Avatar
Re: cab sealer question
3m 8307 I believe. its a self-leveling automix that any jobber will have
TravisH is offline   Reply With Quote
Old 02-02-2008, 09:26 PM   #3
70GMCer
70GMCer's Avatar
That's it
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 02-03-2008, 12:28 AM   #4
dan42
dan42's Avatar
I'm doing mine right now, and I'm gonna use this stuff - it's not self-leveling, but it sticks a little better for the vertical stuff. BTW, did you get a good method of cleaning all the old caulk out of the drip rail? It is a real PITA and time taker just picking away at it, but if you don't get it all out, the rust will come right back.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 02-03-2008, 12:40 AM   #5
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation Re: cab sealer question
Dan don't use that!! It will shrink and crack very bad, I know because I used it on my 72 and now I have to redo it!! Also to clean the old out use a 4" grinder with a wire wheel.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-03-2008, 12:55 AM   #6
Firefighter
look at this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=276071
Yellville, Ar. USA
Old 02-03-2008, 01:07 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Here's a couple of sites to check into re: the 3M product. Not sure which other sealers there are but it's what I found.
http://solutions.3m.com/wps/portal/3...beDDC4KLKK5Wgl
http://yhst-13811118617756.stores.ya...t/dur4229.html
68gmsee is offline   Reply With Quote
Old 02-03-2008, 01:19 AM   #8
TravisH
TravisH's Avatar
Use a bristle brush on a die grinder to clean out most of the old sealer. A couple 3" round ones should get 99% of it out. I recommend using the plastic bristle ones, much better than wire and they don't fly apart as easily
Then use a cutoff wheel to clean the really tight spots that you weren't able to get with the brush. I have an arbor for my die grinder that I use 3" discs on, just used one that had worn down to maybe 1.5"
Old 02-05-2008, 02:09 PM   #9
dan42
dan42's Avatar
Thank you B and B - I will take your advice and use the expensive stuff. I just want to do it once, and for the price, even though it's expensive, in the long run, it'll be worth it.
Philippians 4: 6-7
Old 02-05-2008, 02:43 PM   #10
AuggieStyle
AuggieStyle's Avatar
yeah dan dont take the cheap route on this one especially if you are gonna paint the truck.
8307 3M is what i would use, also SEM has a good product but i dont know the number off hand like i do the 3M but when i get to work monday i can find out.
AuggieStyle is offline   Reply With Quote
Thread Tools
Display Modes
