02-03-2008, 02:01 PM | #1 |
Where to mount MSD box?
I tryed search but nothing comes up. I am installing a MSD box in mine 69 and need to find a good spot for it. Who is running one and where did you mount it? Post some pics if you have it. Thanks
02-03-2008, 02:48 PM | #2 |
Re: Where to mount MSD box?
Mines on the passenger side inner fender. Sorry, no pictures.
02-03-2008, 11:29 PM | #3 |
Nothing to see here.....
you need to mount it where it has decent "breathing space". they heat up and can overheat in the worst case scenario......
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
02-04-2008, 12:35 AM | #4 |
On the inner fender
69 Chevy 4x4 383 Power |
02-04-2008, 02:10 AM | #5 |
'71k204x4454
Mine is in the same spot as haysonj
1971 K20 4x4 1964 buick skylark convertible |
02-04-2008, 02:31 PM | #6 |
knuckle buster..
i shaved my firewall and put a trimmed and painted 1/8" steel plate over the heater holes.first i test fit the sheet, after trimming from my template.. and then i installed a pro-comp ignition set-up (msd-knock-off) came with pc-51 coil, msd box, and billet mag/pickup dissy. then i mounted it back onto the firewall. if your thinkin of going shaved this is a nice place for extras in the bay'..... ill try to post pics later.
hope this helps, good luck!! |
02-05-2008, 03:45 AM | #7 |
Here's where I put mine.....the raised area almost looks like it was made for it and I like it out of sight.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
02-05-2008, 12:01 PM | #8 |
Thanks for the ideas. I mounted mine on the left fender. I couldn't use the right fender due to electrical distribution block mounted overthere.
02-05-2008, 02:16 PM | #9 |
I bent some heavy tin on a break and mounted it to the pass side fenderwell
68 4x4, 454, 4 speed, disk brakes both ends, Sold my 69 SS396 Elcamino when young & stupid |
02-05-2008, 07:10 PM | #10 |
If you were looking to hide it, out of site.
There's room behind the glove box. Not an MSD but that's where I stashed my computer. |
Thread Tools | |
Display Modes | |
