Old 02-04-2008, 12:31 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
1972 Door panels on 1970 truck
What has to be done to install 1972 plastic panels in a 1970 truck??
1971ChevyTruck is offline   Reply With Quote
Old 02-04-2008, 12:46 PM   #2
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Re: 1972 Door panels on 1970 truck
To my knowledge the window crank handle stems are longer on the 72 and shorter on the 70.........if I screwed this info up please let me know. I have a non 72 door on the right side of my truck but used plastic 72 door panels on both sides.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-04-2008, 01:01 PM   #3
QKENUF4U
QKENUF4U's Avatar
yep, the door handle and window crank shafts are different.(72's are longer) easy swap out and your all set.
QKENUF4U is offline   Reply With Quote
Old 02-04-2008, 01:08 PM   #4
1971ChevyTruck
Guess I need a set of 72 window cranks lol the process begins lol
Old 02-04-2008, 01:24 PM   #5
Hoss72
I just installed 72 panels on my K/5 I cut the part that sticks out from the door panel the fabed a patch panel. I think it turned out ok JMO. If you wanty I will take a picture tomorrow.
Hoss72 is offline   Reply With Quote
Old 02-04-2008, 01:26 PM   #6
1971ChevyTruck
Yeah if you would that would be great...last thing I need to find any more parts...missing too many like it is
Old 02-04-2008, 01:29 PM   #7
Hoss72
Yep thats why I did what I did, besides I like the 72 panels they just look good.
Old 02-04-2008, 10:57 PM   #8
72armyswbtruck
72armyswbtruck's Avatar
Me too, I have been a fan of the 72 door panels since the beginning.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 02-04-2008, 11:53 PM   #9
Boog
laying low
Boog's Avatar
So you have to swap out the window regulators and door release to use the 72 panels? Somewhere I've seen some crank handle extenders to accomodate this swap. I've not seen any in use however. They are just splined extensions to reach through the thicker panel. Anyone else seen these?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-05-2008, 12:33 AM   #10
463
463's Avatar
you mite like this teaser. i removed the woodgrain tin inserts and put the s/s trim back on after a redie job. 463
463 is offline   Reply With Quote
Old 02-05-2008, 06:11 AM   #11
Hoss72
Well here is mine
Old 02-05-2008, 09:14 AM   #12
Frizzle Fry
Frizzle Fry's Avatar
If you don't mind a little customizing they can be installed without the longer shafts like Hoss72 did. You can also replace that whole flat section with something else. Here's what I did on a 69 I used to own, and the second pic belongs to "Piece of Work." You could put whatever you want in there covered, painted, chromed, cardboard ...
Frizzle Fry is offline   Reply With Quote
Thread Tools
Display Modes
