Old 02-11-2008, 10:09 AM   #1
pat123
Pat
pat123's Avatar
edelbrock manifold
i have an edelbrock 4 barel high rise manifol for FREE.
but was left out in the weather and corroded inside and out. how can i clean it or is it wearth it?
can i bead blast it or will it wreck the aluminum.
if not will i have to cover up the mating surfaces?
pat123 is offline   Reply With Quote
Old 02-11-2008, 10:16 AM   #2
EyeH8the24
EyeH8the24's Avatar
Re: edelbrock manifold
bead blasting wont hurt the intake,will most deffinatly help it ,
EyeH8the24 is offline   Reply With Quote
Old 02-11-2008, 10:31 AM   #3
pat123
Pat
pat123's Avatar
will it hurt the surfaces?
Old 02-11-2008, 10:36 AM   #4
EyeH8the24
EyeH8the24's Avatar
no it wont ,i have bead blasted alot of aluminum intakes,never had a problem,will clean them to a nice aluminum finish.
Old 02-11-2008, 10:53 AM   #5
Lated
Lated's Avatar
Are you wanting to get rid of the intake? I might be interested if you are.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 02-11-2008, 03:33 PM   #6
pat123
Pat
pat123's Avatar
sorry i was going to try and clean it up
how would i clean the passeges?
Old 02-11-2008, 04:20 PM   #7
skokie
skokie's Avatar
You could take it to your local machine shop and see if they can hot tank it for you.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-11-2008, 11:08 PM   #8
Liz
Catchy title goes here..
Liz's Avatar
please subscribe to the board and post classified ads in the classified sections. thank you
Liz is offline   Reply With Quote
Old 02-11-2008, 11:13 PM   #9
Boog
laying low
Boog's Avatar
Maybe you could use a dremel type tool with the sanding rolls to clean up in the runners and hard to reach areas.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-12-2008, 12:19 AM   #10
72BLUZ
72BLUZ's Avatar
clean it by hand, then try to polish. if that doesnt work throw some paint on it
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 02-12-2008, 04:26 AM   #11
pat123
Pat
pat123's Avatar
ok thanx
but if i bead blast the mating surfaces will it damage them?
Old 02-12-2008, 04:36 AM   #12
andrewt2
andrewt2's Avatar
bead blasting will not hurt the maiting surfaces it will clean up the whole intake for a very nice finsh, but i recomend washing it with a pressure washer after blasting to get the debris out of the runners.
andrewt2 is offline   Reply With Quote
Old 02-12-2008, 05:45 AM   #13
jaros44sr
jaros44sr's Avatar
I don't think you can put alum. in a hot tank, but I could be wrong
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-12-2008, 06:46 AM   #14
EyeH8the24
EyeH8the24's Avatar
you can hot tank aluminum...long as it isnt in a acid bath ,but hot tanking that intake wont help the corrosion much at all....bead blasting it would be the best bet
Old 02-12-2008, 09:09 AM   #15
jaros44sr
jaros44sr's Avatar
Thanks for that info., will keep that in mind...J.
SAFETY FIRST
AS usual, off topic
Jim
Old 02-12-2008, 10:55 AM   #16
pat123
Pat
pat123's Avatar
cool
thanx for your help guys
if theirs anything else i should know let me know
Thread Tools
Display Modes
