Old 02-12-2008, 03:48 AM   #1
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
'71 air cleaner question HELP!!
I am in the process of replacing the thermal switch inside the air cleaner housing, the and vacuum control in the snout. I stripped the old parts out before taking pics. Does anyone have a couple reference pics of the vacuum hoses and the position of the thermal switch? Seems like I read an article some time back about those switches having to be installed a certain way. Also, If that's the case, how does the vacuum hoses run? Which one goes to the carb and which one goes to the vacuum control in the snout?
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 02-16-2008, 07:19 AM   #2
Botietruck
Botietruck's Avatar
Re: '71 air cleaner question HELP!!
TTT anyone have a pic or any info on this/
Old 02-16-2008, 05:34 PM   #3
Luvlegs
Luvlegs's Avatar
It's a little after 5 this morning and the shop lights are too cold to come on yet (I hate it when I can't sleep) - I'll take some pics in a bit... I believe one side or the other from the AT switch goes to the actuator on the snout and the other one went to..... vacuum on the carb I do believe.... Not sure if it matters which side of the AT switch, it just opens/closes when it hits temp.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 02-16-2008, 09:20 PM   #4
Luvlegs
Luvlegs's Avatar
UGH - the aircleaner I have is missing the AT sensor - In my manual, it shows the sensor near the snorkle with the "pointier" end aimed at the snorkle. Mine however (72 250) was located across from the snorkle... sooo, that 'ought to help about.... zero. TTT for ya though.
1972 C10 L6 3OTT
Old 02-16-2008, 11:37 PM   #5
cruiserman
Where did you get the replacement parts?
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 02-17-2008, 05:59 AM   #6
Botietruck
Botietruck's Avatar
Luvlegs, thanks for, well, nothing!! LOL!!
cruiserman, I purchased the sensor, the small piece that the two vacuum hoses connect to, from NAPA. I also purchased the vacuum piece that sits on top the snorkel from NAPA. I believe that part is called a vacuum door motor, or a vacuum motor.
Old 02-17-2008, 06:09 AM   #7
skokie
skokie's Avatar
Got pn#s?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-17-2008, 10:47 AM   #8
cruiserman
Yes, part numbers would be nice, but I'll try NAPA tomorrow. I was told by the dealer they are no longer stocked. I'm used to buying Land Cruiser parts, and if Toyota doesn't have it, it doesn't exist. I forgot that GM sells nothing for older vehicles.
05 Odyssey
08 Tundra
Old 02-17-2008, 06:56 PM   #9
Luvlegs
Luvlegs's Avatar
Originally Posted by Botietruck View Post
Luvlegs, thanks for, well, nothing!! LOL!!.
I woke up swinging there yesterday morning - pretty much fizzled out by 8....
1972 C10 L6 3OTT
Old 02-17-2008, 07:20 PM   #10
Botietruck
Botietruck's Avatar
cruiserman, I have bought several pieces for my '71 from GM recently. There's alot that has been discontinued, but if you have the old part numbers sometimes they can get it.
Try these NAPA #'s. Not sure if they are the ones for these parts, but out of all my receipts, I believe I have narrowed it down to these.
2-2202 sensor -(inside the air cleaner housing-the 2 vacuum hoses connect to this piece)
22259 - motor- sits on top of the snorkle
Good luck!
Old 02-17-2008, 07:22 PM   #11
Botietruck
Botietruck's Avatar
Luvlegs, I noticed last night that someone had a 6 cyl. air cleaner for sale on the board and had posted the pics...just what I needed! Did you get that air cleaner set up completed that you were working on several weeks ago?
Old 02-17-2008, 07:59 PM   #12
Luvlegs
Luvlegs's Avatar
yepper - let me see if I can find some pics.... (mine is an offset setup to clear the brake booster)
1972 C10 L6 3OTT
Old 02-17-2008, 08:06 PM   #13
Luvlegs
Luvlegs's Avatar
I didn't have the hose on from the carb riser to the valve cover but you can get an idea... (seems like everything I add on is black.... )
1972 C10 L6 3OTT
Old 02-17-2008, 10:25 PM   #14
Botietruck
Botietruck's Avatar
Luvlegs, I found the correct size PCV hose at the Caterpillar dealer where I work. I have the Cat p/n if you are interested. I believe it's made by Gates, and it is PCV hose. If you are interested and can't get it locally, let me know. I paid about $6.00 for mine. Do you have a Gregory Poole Cat dealer near you?
Old 02-18-2008, 07:46 PM   #15
Luvlegs
Luvlegs's Avatar
I found a piece of hose in my shop - I think I picked it up when I cleaned out a maintenance shop in a mill that was closing.... I think it's just heater hose - it works and looks good though. Are you looking for an offset aircleaner or the regular kind?
1972 C10 L6 3OTT
Old 02-18-2008, 11:24 PM   #16
Botietruck
Botietruck's Avatar
I have the offset air cleaner setup, just have not had time to install it...not that I need it right now. The truck is several months away from being ready for the road.
Old 02-19-2008, 03:11 AM   #17
cruiserman
Thanks for the part numbers.
05 Odyssey
08 Tundra
Thread Tools
Display Modes
