Old 02-19-2008, 11:12 PM   #1
1987_3/4ton_chevy
Cowboy Up
What size Air Filter
Hey, i am in the progess of buying a new air filter from Amsoil. I'd prosonal would like the big air filter lik a 14 inch size, hieght of the filter, 6 inch. Do you know if that would fit under teh hood of a 350 small block engine? Or is that something i would have to check out and look myself? If you wanna see the photo go to www.amsoil.com and the part number is EaAR2106. Thanks
1971 chevy k10 *Under the Knife*
Chris Cary
1987_3/4ton_chevy is offline   Reply With Quote
Old 02-23-2008, 06:33 PM   #2
1987_3/4ton_chevy
Cowboy Up
Re: What size Air Filter
hello...
Chris Cary
Old 02-23-2008, 06:44 PM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Don’t think anyone can recommend one way or the other not knowing your setup. Just too many variables that will affect this.
I would recommend cutting a cardboard box and try different sizes to check different clearances.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-23-2008, 06:51 PM   #4
crazy longhorn
Fabricate till you "puke"
I have a 14x4 on an edelbrock rpm intake/3/4" spacer , & a 3310 Holley. The truck also has 1 1/2" body drop(fits snug). My guess, is if you are rock stock(intake,carb,ect), a 6" tall filter will fit.....but you dont need that much height. crazyL OOPS , mine is a 69
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-24-2008, 12:43 AM   #5
Orange
Licensed to Thrill!
Orange's Avatar
If a 4" is tight - I don't see 2" more making it in there.
Just stick with the regular old 14x4 Amsoil - they are good filters. The best foam style available - and the only one I would recommend. They don't break down like the others.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Thread Tools
Display Modes
