Old 02-20-2008, 07:18 AM   #1
TireSmoke420
One of the few GMC'ers
TireSmoke420's Avatar
EGR Valve???
ok so my 87' keeps throwing codes up for the egr valve. now i have taken the smog pump off of my truck. so now my question is would i be better off to replace the egr or buy/make a block off plate?
87' Silverado 4x4
"Young, Dumb And Full Of Cum"
TireSmoke420 is offline   Reply With Quote
Old 02-20-2008, 08:58 AM   #2
chemsearch
Re: EGR Valve???
hey, if you're not worried about passing emissions at all then you might as well go with the block-off. Cheaper and will help your engine run a little better
1986 Chevy K10 4x4 305 Auto
chemsearch is offline   Reply With Quote
Old 02-25-2008, 06:55 AM   #3
TireSmoke420
Re: EGR Valve???
anyone else have any input? i bought the block off plate havnt put it on yet will firstthing in the morning. im still a lil weery puttin holley junk on my truck lol
87' Silverado 4x4
Old 02-25-2008, 09:20 AM   #4
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
Re: EGR Valve???
I don't think egr's are that expensive, but again if you arent worried about smog i would go with a block off. they just put exhaust back through your intake and sometimes crud up the carb if the egr is going bad. Im not sure what you would need to do to use a block off plate and still not get any check engine codes though.
1975 LWB C-10 Silverado
- Stock
- "BIG 10"
- 4 Bolt 350 "Brand new" 1200mi
- THM-375 "Brand new w/trans cooler" 5000mi
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
SRH916 is offline   Reply With Quote
Old 02-25-2008, 09:53 AM   #5
benoit454
Chris
benoit454's Avatar
Re: EGR Valve???
I had to take it off our 84 when I put on an edelbrock carb. I bought the holley plate for $12 and a gasket and blocked it off, then removed the smog pump, now just gotta take off the air tubes. I wouldn't think twice about yanking it off long as she still runs good with smog pump gone you'll be fine I think.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 02-25-2008, 09:58 AM   #6
SRH916
SRH916's Avatar
Re: EGR Valve???
How did you go about taking the smog pump off? I've got one on my 75, but there is no need for it anymore.
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 02-25-2008, 10:58 AM   #7
benoit454
Chris
benoit454's Avatar
Re: EGR Valve???
I haven't removed it yet just cut the belt off of it.
As far as I know there's bolts that hold it to the block then clamps or something to hold the hoses on to it.
Shouldn't be hard to remove I wouldn't think.
After removing the egr and even before when you'd rev our up it backfire real bad out the exhaust and the smog pump was doing it, with the belt cut off it doesn't backfire at all.
Chris
GIT R DONE!!!!!!
Old 02-25-2008, 09:43 PM   #8
Poopski
Poopski's Avatar
Re: EGR Valve???
You could have easily made a block off plate using parts from the egr and some sheet metal.
1985 Chevrolet C10 305 2wd LOOOOONG Bed
Broke as a joke and funny as a funeral
Poopski is offline   Reply With Quote
Old 02-25-2008, 10:49 PM   #9
benoit454
Chris
benoit454's Avatar
Re: EGR Valve???
yea but when you don't have the tools or the metal it doesn't leave you with many options.
Chris
GIT R DONE!!!!!!
Thread Tools
Display Modes
