02-21-2008, 02:57 AM | #1 |
Insert Title Here
15X8's and 15X10's what backspacing
I am going to be ordering some 15X8 fronts and 15X10 backs for my truck.. what backspacing should i get.. i did a search and cant find what i need... i want the wheels to be deep lip as possible but still be able to tuck when lowered..The rears will be a 295/50 and its a 69 short fleet with trailing arm suspension..Thanks
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 02-21-2008 at 02:58 AM. |
02-21-2008, 03:09 AM | #2 |
Re: 15X8's and 15X10's what backspacing
Check my build thread for quite a few photos, but the wheels I have are 8 and 10 with 4.5 backspacing on all 4 corners.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
02-22-2008, 07:53 AM | #3 |
I was thinking about doing 15x8's with a 4" backspace and 15x10's with a 5" backspace...
im curious too, so here is a ttt
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs http://67-72chevytrucks.com/vboard/s...d.php?t=272458 2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds Last edited by chevguy7; 02-22-2008 at 07:54 AM. |
02-22-2008, 09:42 AM | #4 |
4 1/2 " in the rear is max without rubbing problems
I BELIEVE IN JOHN 3:16 |
03-10-2008, 08:11 AM | #5 |
Insert Title Here
so 4.5 on both the 8" and 10" will work.. anyone have pics of this set up?
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
03-17-2008, 10:58 PM | #6 |
Insert Title Here
okey dokey, i guess ill do 4.5 all around..lol
03-18-2008, 07:14 AM | #7 |
I have a 15x10 with 4.5 backspacing in the rear with 295-50-16 heres some pics. But i have 6's up fronts so that wont help.
03-08-2009, 06:11 AM | #8 |
Isn't the 67-70 rear end narrower than the newer ones? I want to eventually put 10 wides on my 72 step but don't know if 4.5 backspace would stick out. It would only lowered about 3" so I want it to fill the fenders to the outside pretty much to the edge. Anybody have some advice?
'72 cheyenne super step, '05 long bed gmc |
03-08-2009, 10:35 AM | #9 | |
What works for one guy may not work for another. Not many people have the cash laying around for 'hoping' they'll work . ......
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-08-2009 at 10:36 AM. |
03-08-2009, 11:56 AM | #10 | |
I even tried to start a thread for rear wheel spacing...(e.g. Type of bed, which rearend, width of rim and backspacing) as there are a few variables but again they would just post backspacing with no mention of short or long rear.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 03-08-2009 at 12:07 PM. |
03-08-2009, 01:54 PM | #11 |
laying low
Has anybody noticed this is an old thread brought back up? Did 1lowc10 ever get those wheels? Also it is my understanding that a 15" front wheel with that much backspacing will scrub on the control arm in the lowered position. Is that not the case?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
03-08-2009, 02:14 PM | #12 | |
03-08-2009, 02:46 PM | #13 |
Typical truck ralleys are 15x8 w/4" back spacing.
03-11-2009, 10:23 PM | #14 |
So when I eventually get to measuring the wheels couldn't I just add 2 inches to the backspacing measurement as I like the offset I have and the new ones would be 2 inches wider? Because backspace adds to the back right? They sit right at the edge of the fenders now.
03-11-2009, 10:35 PM | #15 | |
03-11-2009, 11:53 PM | #16 |
whats the difference between backspace and offset
03-12-2009, 11:45 AM | #17 |
Junior Member
This helped me understand difference between the two.
Thread Tools | |
Display Modes | |
