Old 02-26-2008, 10:06 AM   #1
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
Slowly but surely its getting worked on
well i havent been around here much (if it all) lately, but i finally found the time to work on the old truck. this will be my slow moving build page. some history of what it started out as and what it is now
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 02-26-2008, 10:09 AM   #2
68w/sbc406
68w/sbc406's Avatar
Re: Slowly but surely its getting worked on
i have only had the parts for 3-4 years to do this but i now have a little bit of free time and a place to do it. its nice to make progress every once in a while.
we all know what they look like at first
and now
Old 02-26-2008, 10:10 AM   #3
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
WOW!!!!
nice job!!!!!!!
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 02-26-2008, 10:22 AM   #4
68w/sbc406
68w/sbc406's Avatar
i built these a few months ago and they are finished i just dont have any finished pictures of them. i put alpine type r components in them and powered them with a 2 channel amp. sounds darn good
Old 02-26-2008, 10:25 AM   #5
68w/sbc406
68w/sbc406's Avatar
Originally Posted by 72swb_327stroker_? View Post
WOW!!!!
nice job!!!!!!!
thanks, i am too anal to do a half assed job, but not rich enough to do it perfect
Old 02-26-2008, 10:48 AM   #6
redhead69
fugedaboutit
redhead69's Avatar
cool stuff.. good job, man I see alot of sanding has gone into those kicks.. are you going to paint them to match the truck or cover in fabric?
Currently truckless
redhead69 is offline   Reply With Quote
Old 02-26-2008, 10:58 AM   #7
68w/sbc406
68w/sbc406's Avatar
right now they are a gloss black but in the future (way future) when i do the interior i would like to do gray leather and wrap them as well
Old 02-26-2008, 11:07 AM   #8
68w/sbc406
68w/sbc406's Avatar
here they are finished with a rattle can
Old 02-26-2008, 05:35 PM   #9
68C15
blood type; Retumbo
68C15's Avatar
14" from spindle to fender lip? that will look good with a 255/70-15. but I think I would throw a set of 2" spindles at it. just to get the ride height kool while having good ride/geometry.
that engine bay looks sweet as well
68C15 is offline   Reply With Quote
Old 02-27-2008, 05:40 AM   #10
68w/sbc406
68w/sbc406's Avatar
the main goal is the disc brake swap. i havent lowered the back at all yet so if the front is up a bit high that is just fine with me. i am running 275/60/15 on all four corners. after i tackle the back i will look into drop spindles up front
Old 03-11-2008, 11:40 AM   #11
68w/sbc406
68w/sbc406's Avatar
got a bit farther this weekend
Old 03-11-2008, 11:42 AM   #12
68w/sbc406
68w/sbc406's Avatar
granted that is tire on the inner fender well and it would be ripping the brake line out. do they make longer brake lines for going that low? that upper ball joint angle is nasty sitting like that
Old 03-17-2008, 08:06 AM   #13
68w/sbc406
68w/sbc406's Avatar
well today consisted of new brake lines from inline tube. i replaced all the front tube and the rear tube from the prop valve back to the flexible line conecting to the axel. i will save those tubes for another day. also i mounted my booster and ran the vacuum line and put the new MC on. i will be taking the factory prop valve out and putting a SSBC adjustible in its place
Old 05-12-2008, 07:06 AM   #14
68w/sbc406
68w/sbc406's Avatar
well after having issues with the rotors (which ECE took care of no problem) and a ball joint issue, and working 8 weeks of swing shift, this project is done. i could go lower but i would have to remove the inner fenders and i dont want to do that
Last edited by 68w/sbc406; 05-12-2008 at 07:47 AM. Reason: pictures were way too big
Old 05-12-2008, 07:13 AM   #15
68w/sbc406
68w/sbc406's Avatar
more pictures
Old 05-12-2008, 07:53 AM   #16
sickchevy68cst
Rice Killing 101
very nice whats the drop numbers on that kit?
distrubin the peace since i got the thing and broke the origianl radio on 95.5 classic rock
Ride:
1968 c20 lwb 327(orig motor)/np435/eaton 4.10 w/posi
puttin in a 496 rebuilding trans need to rebuild diff :|
need to start takin pics and start a project thread
sickchevy68cst is offline   Reply With Quote
Old 05-12-2008, 08:01 AM   #17
68w/sbc406
68w/sbc406's Avatar
well the fender lip started out at 33 inches off the ground, and i can get it down to 23-24 inches, so 9-10 inch drop
Thread Tools
Display Modes
