Old 02-27-2008, 09:37 PM   #1
cochino12
It followed me home?
cochino12's Avatar
2 questions, lift and steering
I did some searching and couldnt really find what I needed so I thought I would ask again. The steering on 85 3/4 4*4 (origianlly 1/2 ton) wanders a lot but mainly at speeds below 40 mph. It does wander a bit at higher speeds but Its not as noticable. I have checked the frame at the steering box and there arent any cracks, it does have dual steering stabilizers but they look pretty old, also the truck has what looks to be 6" lift springs in front and only 4" block in the rear. Could the problem just be a bad steering box?
My second question is about the lift in front, can I just remove one of the leafs to make it sit level? I would rather lower the front a little than lift the rear.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-27-2008, 11:42 PM   #2
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Re: 2 questions, lift and steering
Have you had it aligned? Sounds like the toe is outta whack...either that or bad tierod ends/draglink ends...
Do ya have a dropped draglink or a raised steering arm???
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 02-27-2008, 11:50 PM   #3
cochino12
cochino12's Avatar
Not yet but I have an appointment for this weekend to get it done. Forgive my ignorance but is toe when the tire leans to one side / ? It does have a 4" raised steering arm
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-27-2008, 11:58 PM   #4
69BBsuburban
Toe "in" is when the tires point towards each other when looking at front of vehicle....toe "out" is the opposite.
Generally, having a little toe in, @ 1/8" or so....tracks better.
If your tires are 'leaning'....thats camber. Jack the truck up and graba tire at the top and bottom and pull alternately on each...if it moves, you've got bad balljoints...or wheel bearings
Pinstriping by Josh
1930 Ford Model A
Old 02-28-2008, 12:08 AM   #5
Mudder
Mudder's Avatar
It could be a lot of different thinks. Tires? Steering linkage worn? Good question for the 4x4 forum.
Mudder is offline   Reply With Quote
Thread Tools
Display Modes
