Old 02-28-2008, 07:31 PM   #1
Eyegore
What Hump?
Eyegore's Avatar
Removing rotor off a dana 44
Help we cannot seem to get the rotor off the right side front. We removed the hub and so forht but cannot seem to pull it off. The front bearing and seals need replacing, fluid is leaking from the inside of the hub assembly. Anyone have words of advice or a schematic of it.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 02-28-2008, 09:21 PM   #2
Burt4x4
Burt4x4's Avatar
Re: Removing rotor off a dana 44
This is how I doit:
Remove tire
Remove Brake caliper, two bolts
Remove hub assy, outside screws, inside = outer ring & center snapring
Insert Wheelbearing socket to remove wheelbearing nut, then washer, then second nut.
Yank Hub assy off spindal with two hands
Clean & rebuild ...
Good luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 02-28-2008, 10:39 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
You got to have the hub/wheelbearing socket or it's not coming off. The socket isn't expensive and well worth it. You don't want to try removing the nuts with a hammer and screwdriver. It will take forever to remove and ruin the nuts themselves.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-29-2008, 09:13 AM   #4
Eyegore
What Hump?
Eyegore's Avatar
thanks guys appreciaye the help
Lil red 86 c-10
99 Sub
Old 02-29-2008, 11:30 AM   #5
Billhilly
Billhilly's Avatar
This any help? http://www2.dana.com/pdf/5310-3.PDF
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Thread Tools
Display Modes
