03-01-2008, 08:21 AM | #1 |
2 inch lift question
As most of you know there are constantly lift kits being offered on E-Bay for our trucks. My stock springs are OK but I would like to replace everything when I restore the truck. The people on the bay offer a 2 inch lift for reasonable money- my question is will this kit mess up the stock appearance etc. of the truck? I am going back stock, but this would get me springs cheaper than I could replace with stock ones. What about stock brake lines hoses steering? This 4x4 stuff is going o drive me crazy! Also how tall were the stock tires on the standard 6 lug 15 inch wheel. Thanks for your time, Harold
03-01-2008, 04:10 PM | #2 |
Re: 2 inch lift question
2" isn`t enough to need other changes.No need to change shocks,lengthen brake lines,etc.I`d say it`s an acceptible original-like change.I`ve had a couple with spring work that raised them right about 2".They just sit "healthy" and look great with factory size tires.Is yours a K/10 or K/20?
03-01-2008, 09:32 PM | #3 |
K5Camper
Depending on how de-arched your stock springs are, you may notice a little more net lift with 2" springs. I wouldn't worry about it through as the lift springs will settle too.
It should look just fine, plus at that size you shouldnt really need any steering corrections other than a draglink adjustment.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
03-02-2008, 08:41 AM | #4 |
Special K it is a K10. Thanks for the information
03-02-2008, 10:14 AM | #5 |
this is what i want to do to my K10 to, just a mild 2" all spring lift. mostly to make the sob ride better, someone put 1 ton springs in the rear at some point and it rides like a freakin lumber wagon. there like 10 leafs thick, and the front have 3 leafs i think there stock tho
03-02-2008, 11:54 AM | #6 |
BlahBlahBlah
This is a 2.5 inch lift all springs. Skyjacker soft rides. No mods were necessary to steering etc. I did put braided brake lines in place of the rubber ones. My old ones were pretty shot and I thought the braided looked kinda cool. I believe they were a little longer than stock, but it wasnt required. Course now they are all dirty and grungy, so much for cool...lol.
The wheels are 15x8 with 33in tires. |
03-02-2008, 08:02 PM | #7 |
I like the looks of yours CG. Thats about the look I'm going for.
I went with 2.5" skyjackers too, just because I needed to replace my old stock ones and it was the same money if not cheaper than stock replacements.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
03-02-2008, 09:22 PM | #8 |
20' Daredevil (Ret)
I also have 2.5" Skyjackers and my K20 sits just like CG's truck (with 33-12.50/16.5s on 9.75 wheels). My kit came with blocks for the rears but I didn't use them -- I have a single add-a-leaf in each rear spring pack.
Can't beat the quality of Skyjacker...
03-03-2008, 08:51 AM | #9 |
^It just looks right^
03-04-2008, 01:01 PM | #10 |
With new stock springs and cab bushings, you might see 2" at the fender...
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
03-05-2008, 02:27 AM | #11 |
I upgraded my k10 to 3/4 ton springs, 7/1 overload springs in the rear, and 3 leafs in the front. It lifted the rear 3.5", and the front 2.25" in the front. Yes it does ride like a lumber wagon, but I can put a ton in the rear, and it'll sit level. I didn't have to modify anything, just bolt in the new spring packs, with new u-bolts, and shackle bolts, do a quick toe-set, and I was driving down the roar
Mine is a 350, with the TH400, 1 piece driveshaft, to a 10 bolt rear-end Thanks Duro
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project |
Thread Tools | |
Display Modes | |
